I inherited a box of woodworking tools, and there were two of these Vicegrips in the box.
I’m sure plenty of you know what they’re for…. care to clue me in?
Use it on your drill press table as a hold down for your work. The lifting eye on the threaded stud is the wing nut. drop the stud through a slot in the table.
As Dave has pointed out these are used in many places for stationary hold downs .
The RAS or a Chop saw even as a bench hold down .
Maybe as a hold down on a jig or fixture , panel router / saw ?
Seams like there were some called "Sta Fast" er sumthun like that.
You will find a good home for them we know .
regards , dusty
Aha! That explains why it was in the same box with a drill press machinist's vice and a mortiser. Thank you both.
How can I put it delicately? This tool can be used in an emergency situation, namely when you run out of Preparation H :-0
Well, yeah. That was the other use I was thinking of. :-)
The eye was what had me baffled - I figured it was for a piece of 1/2" rope for something. But as a thumb nut to turn it with, that makes sense.
Brent,
LV sells one:
http://www.leevalley.com/wood/page.aspx?c=1&p=46046&cat=1,43838,43845
I used to have one for my drill press. Very handy until someone walked with it. You can get a new one through Lee Valley under the jigs and hold down section of clamps for about $20.
Chri7s
