Enquiring minds….
Just cleaning up and on a whim counted up my router bits.
I don’t use the routers very often.
So counted while I cleaned. Not counting trimmers, have 39 bits.
Is this pathetically small, normal or an over the top amount?
What’s your average? What do you have the most of? All colors count 🙂
Surprised FWW hasn’t done a poll on this.
Boiler
140 in the spots their supposed to be in, a few more loose. All Bosch.
Men will never be free until the last king is strangled with the entrails of the last priest.
~ Denis Diderot
OOH RAH!That's some bits there boss.
Must be like marshalling a little army.Boiler
You would have me go looking! I just found another 18 in a drawer. I need to go get another multi drawer cabinet before I forget them again.
I realized while looking through them that I recently bought one I already had.
Those 18...deserters?
And how many have you, or do you use on a somewhat regular basis, I wonder.
ASK
Well lets see . . . there are the three shown here (one in the router ) and then there is the second narrow one that I ground even narrower . . . I count four. : )
http://www.veritastools.com/Products/Page.aspx?p=112
roc
Edited 4/15/2009 9:52 pm by roc
I always seem to have one or two less than I need. ;-)
Ralph,Same here. New occurance (for me)just last week though. Had to have a special size made up by Whiteside. Wonder if I'll ever use it a second time. As to the rest, now I wonder when I look at em if I didn't see a bit or it's just a creeping case of CRS.Boiler
I don't know how many bits, I do have 17 routers.
Tom
i
Now there's a thought!
Is that where you store your bits?
I'm going to have to get more routers.
Dgreen will have to get a new shed.Boiler
I'm feeling inadequate. That man has as many routers as I have bits.
>as many routers as I have bits.I almost asked "How many of them still work ?" : )rocGive me six hours to chop down a tree and I will spend the first four sharpening the axe. Abraham Lincoln ( 54° shaves )
Edited 4/19/2009 7:09 am by roc
I can muster 45 bits, four routers, two fences and one router table on a good day.The 'lectric stuff gets deployed when there's a time factor.
Tom,I always joked routers are like clamps, you can never have too many of them, but whoa seventeen routers, that's a lot of routers...
Edited 4/19/2009 9:09 am ET by BOBABEUI
Bob,
It is not something I am proud of , I have since received therapy and can safely state that there will not be an 18th router.
Tom.
That's quite a herd, I'm feeling deprived with only nine.
Have you seen the new Feswalt? 46,000rpm variable to zero with a variable collar clutch from dremmel size to 1' concrete trimmers.
It comes with a payment schedule so you can hide the payments from SWMBO.
Comes in candy apple red.
Dustless
3 phase
watercooled
Articulated for locking into a horizontal plunge mode
also has a gimble for radial circle cutting when in lathe mode
a must have for any serious woodburner.
Edited 4/20/2009 10:12 am by boilerbay
Boil,
As a matter of fact I have , I called Feswalt to prod them for more details. I must say, tightlipped bunch over there... I did get this little tidbit though, All the features you mentioned less the 3 phase instead powered by a twin turbo micro diesel therefor making it cordless. My fingers are crossed.
Tom.
cordless is good!
5 router, 43 bits.
Liar! LOL (joking so don't get offended)
Don,Looks like your army is still in charge of the field!BoilerHow many redundant PC collets though?
I guess I will be skewing the poll results.
0 bits
0 routers (not counting my Stanley #71).
Sounds about right to me. Often times I'll have three routers set up at a time for 1 project, 4 or 5 standing by for laminate trimming, a couple in the router table, 4 or 5 mounted up in jigs,
As for router bits, I lost count long ago, but I betcha it'son the high side of 200, buncha duplicates of course.
Router bits is more prolific than rabbets! gotta keep em in seperate cages!
Eric
Thanks Eric I feel some what normal now. Cowtown? I'm guessing Ft Worth.
Tom.
Edited 4/19/2009 8:19 am ET by gofigure57
Nope- it's Cowtown Alberta (calgary)
just mounted one of the extra laminate trimmers on a spare zero clearance blank for the table saw so that I could use a sled to cut gear teeth for that wicked box joint jig . Found the router bits to cut the profiles in the stash.
cut 30,40,12,16 tooth gears.
good thing I hadn't thrown them out eh?
I have about 46, mostly 1/2" shank, at least a dozen are straight bits.
Didn't realize I had so many until you asked, 72 plus a dozen or more in storage. The majority are yellow, probably Carbtech from Woodworkers Supply back when they were in town. There's a few I hardly ever use but most of them are put to work regularly. Out of a dozen brands, I can't say any are necessarily better than others, the old HSS Craftsman's being the exception which are in a dark corner somewhere.
Your right you clean up a little and you find all kinds of treasures that you forgot about (I found new ones that have never been used), 83 router bits that I counted and there is probably a few stragglers (not sure about your shop, but they go in hiding around here until the day after you where looking for them), about half green LV the rest are a mixed up lot. I have only four router's though and after reading this, that is probably not enough in ratio with the number of bits I have.
Let's see.... 8 bits that I use on a regular basis plus duplicated of some of them so I don't have to stop in the middle of a job to purchase a new bit plus another dozen I use on a semi-irregular basis plus a few that were purchased for one special job or another. So... bottom line... 30 pieces. If they can't be sharpened, I give them away or toss them. All of various brands plus a few custom-made ones.
SawdustSteve Long Island, NY (E of NYC)
50-60 bits, 5 routers.
