I have been asked to give a quote on one of these types of setups. The client wants bookcases on either side of the bed and a tv in the structure where the bed retracts. I have contacted the company and they send the drawings for the bed setup. I’m wondering if anyone has done this? And if so, what should I be on the lookout for? thanks.
http://www.zoom-room.com/designCabinet.asp
robin
Fine Woodworking Recommended Products
Armor Pocket Hole Jig Model APJ14001
The jig’s primary design feature is that the depth guide on the drill bit is set when you clamp material into the jig, so it is always right for the material thickness (from 1⁄2 in. to 1 1⁄2 in.). A color-coded system of screws tells you which screw length to use for each material thickness. A starter set of screws is included. The jig and screw system work as designed, with the exit holes well centered in material of varying thicknesses.
Starrett 4" Double Square
Head is easy to remove, replace, and lock down; narrowest blade, at 5⁄8 in., made it easier to fit into tight places; hard to read under bright lights.
Titebond I
Perfect glue for almost every type of glue up. Sets quickly so you can keep working.
Bahco 6-Inch Card Scraper
The size and thickness are what matter here. A consistent performer, this Bahco scraper is found in many shops we visit.
Leigh RTJ400 Router Table Jig
Spacing: Fixed Stock width (max.): 16 in. Stock thickness: 1/8 in. to 13/16 in. for through-dovetails (pins board can be 1-1/4 in.); 1/8 in. to 13/16 in. for half-blinds Half-blind depth: 3/8 in. to 19/32 in.
Does your customer want a Murphy Bed in the cabinetry package? I don't think that website actually has a bed.
In looking at the drawings and talking to the supplier, they (zoom room) supply the bed. and yes, the client wants a bed "just like in the picture". I just have to do the cabinetry component.
Very interesting, but as I read the material I wonder if the clients realize that all the bedding except for the fitted bottom sheet probably has to be stripped before the bed can be closed up. This doesn't have to happen with the traditional Murphy bed. And, have they actually lain on one of the beds and mattresses? I know that the customer is always right, but it doesn't hurt to check that they are going into this with eyes open.
Your clients must not have back problems of any kind. A mattress that will flex like that isn't going to last long at all under the load of a sleeping human. Children maybe? Cool idea though!
It's a foam mattress. Some of them are very high-end (thousands of dollars).
I have one of those "high end" foam mattresses -- memory foam. Not sure how it would respond to that mechanism.forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
This is actually going to be a "spare room" type of situation. They want this is a building destined to be the "pool house". Basically it's an extra living space they are having built. So, it won't get everyday wear and tear. All I know it that I have to design bookcases on either side, with doors, and it has to "match" the rest of the decor! It would be a very nice project to build.
