I hope I can describe this so you know it’s NOT like so many of flap-wheel sanders you get when you google on them.
On TV I saw a man with a buffer (grinder with extended spindle) and what I’ll call a flap-wheel sander EXCEPT instead of strips of sandpaper (the flaps) there were a lot of what appeared to be narrow strips of sandpaper. Like a coarse haired brush, but very flexible “hairs.” He said it was 320 grit, used for contour sanding. Appeared to be 3 or 4 inches wide.
I have googled a lot of variations and can’t find anything close.
Any ideas of what this might be called and where I could get one or inquire about?
Alan – planesaw
Edited 5/16/2008 4:59 pm ET by Planesaw
Hello Alan ,
I know they use cloth buffing wheels for Brass and possibly the abrasive wheels used for polishing rocks and stones and granite and such may lead you in the right direction .
dusty
Might it be the sanding mop?
http://www.stockroomsupply.com/The_Sanding_Mop.php
Jim.
I think you are probably correct. The one I saw looked a bit different, but I would guess it was another brand of sanding mop.
Any ideas of various brands?
Alan - planesaw
I'm in Canada, and the source I gave you is the one that I buy from, usually at wood shows. As far as I know, sander mops are widely available, and googling should find a US source. All the ones I've seen use Klingspor abrasives, which you can find on the Klingspor website under Specialty Abrasives, where they're called Sanding Stars. There's also a smaller version called Flutter sheets which I assume are the same as the mini-mops sold by others. The kit sold by Stockroom Supply includes an arbor and some plastic discs which seem very similar to what others sell. Hope this helps,
Jim
Thanks again. And, I think I have found someone locally who has them.
Good to know about picking them up at woodworking shows.
Alan - planesaw
I buy my sanding mops from Klingspor. I love them and have been using them for a few years now.
http://www.woodworkingshop.com/cgi-bin/ADDA487E/mac/qryitems.mac/itemDisplay
Check out Sand-Rite, I have two of the sand-rite heads, one with 100g load and the other with a 220g load.
They have strips of sandpaper backed up by bristle brushes for contour sanding.
Alan,
Sand-Rite is the place with what you want. There are also cheaper Asian versions of the same thing. I have had both, and both are wonderful tools. You can customize a new unit from Sand-Rite with flap heads or pneumatic drums. Each have their strengths. I find the flap heads more versatile.
Used 3 phase flap sanders can often be had on Craig's List for cheaper than the $1000 for a new Sand-Rite. Typically 2 hp, they are too much machine for the casual user. Here is the URL for Sand-Rite: http://www.sand-rite.com/db-612-dlx.html
Bill
