While assembling a store-bought bookcase, I managed to break a couple of screw-posts, and the store I bought it from can’t help me with getting parts. (That’s another story, deep sigh.) I’ve attached a picture of the screw post I’m talking about (a non-broken version). I don’t even know the proper name to call these things, which is impeding my ability to search for it 🙂
The screw show is just shy of an inch long (as shown by the 1/4″ grid paper in the background), and is designed to thread into veneered particle board, and then be captured by a cam-lock. I know it’s a bit out of focus — my digital camera wasn’t happy focusing this close.
I’ve tried every variant of “cam-lock parts” I can think of, but can’t seem to actually find a supplier on the web. I did find a zillion references to furniture that’s to be assembled with cam-lock fasteners, but no source of actual supply for the fasteners themselves.
Any help would be greatly appreciated.
-M.
Mark,
Lee Valley has what you want. http://www.leevalley.com/hardware/page.asp?page=40049&category=3,41306,41319&abspage=1&ccurrency=2&SID=
Look in their hardware section under fasteners.
Dan Kornfeld, Owner/President - Odyssey Wood Design, Inc.
Edited 10/30/2004 3:07 pm ET by Jackie Chan
Looks to me like it is a 5mm screw in cam lock pin. You could try a shelving/storage place like closet world, etc. It's about a $.05 part. This would be your best bet of locating one, they are used for RTA assembly and usually sold through the larger distributors.
If you have a hard time locating one, I have the 'Mushroom" type with a plastic sleeve that expands when the camlock is engaged, fits in a 5mm hole.
Craig is right - it is the 5mm type.
I'm the other side of the pond otherwise I'd stick one in the post to you - maybe someone closer may volunteer. What is wrong with shops these days - how stupid do they have to be.
Hope you sort it out.
T
Along with the other sources mentioned, Rockler carries this stuff as well.
Mark --
Dan's lead to Lee Valley may get you what you need. However, there are lots of sizes of those things, and you might need to look further. Woodworkers Supply (http://www.woodworker.com) has some which they call "two-piece KD fitting"; one part number is 866-504. Hafele (who I think invented them) has a large variety of them, but Hafele only sells wholesale, so you'll need to find a cabinet shop or somebody who can order from them. Hafele's name for them is Mini-fix, which might give you another google term.
Good luck!
Jamie
Mark,
Check these guys out.
http://www.profhdwr.com/index.html
Look on the fastener page for specialty fasteners. They sell the type of hardware you may need. Look for the Klix Cam products
J.P.
Edited 10/30/2004 8:06 pm ET by j.p.
Thanks everybody! With the correct name for the item, and the leads you all gave me, I believe I've found what I need and have already ordered it! Much appreciation for the fast replies.
-M.
If what you get is still not right, go to a stereo shop that sells knock-down cabinets. They usually have extra parts like these.I cut this piece four times and it's still too short.
Get me some more specifics on the size and what not. I probably have some and will sent them to you . It would help if you can get a name of the the apposing part. these usually have a name and in some cases a part number.
So far, I have not found the exact configuration that you have. But, you might want to try your local Ace hardware store. I have been into a few of them that have a tray of K.D. fittings. Check where they have those little pull out tray of cotter pins, specialty hardware and what not.
The ones I do have the same thread length, but the shank length is shorter and the phillips end is a little shorter/thinner. They still might work.
Edited 11/18/2004 3:36 pm ET by migraine
