I recently bought a used spindle sander to make router forms, but I have come to find out that it can do much more. For pieces up to about 3 inches wide, whether curved or straight, all you seem to need is a couple of passes each on the spindle sander, first at a rough grit, and then at a medium grit, followed by final sanding by hand. No more ROS swirls, no more scraper frustration, and far less tedious hand sanding, (only to discover planer/saw marks that did not come out). My woodworking is reinvigorated! Why did nobody tell me about this sooner?
I am actually torn beween getting a less expensive smaller one right now (like the Rigid or Delta) or waiting a little and getting a full sized one like the Griz or Jet. Been wanting one for a while now. But just recently got a large enough shop for the additional tools.
What do you mean by smaller or full sized? The Jet & Delta are about the same footprint. The Jet has a more powerful motor, the Delta is 1/3 hp.????? The Delta works good for me but I'm not a pro shop either.
James
James
Actually I was referring to the Jet JOVS-10 or Grizzly G1071. They both have 1 hp motors and larger tables. The smaller Rigid, Delta and the like are around $250 +/-. The Grizzly is $690 with delivery. Local woodworker supply has the Jet for $949. To me I think the larger units are worth the extra cost / wait.
I almost bought the Sears combination machine (belt, disc, spindle). But held off and after reading some comments on it. Glad I didn't.
Edited 1/22/2008 9:23 am ET by benhasajeep
Edited 1/22/2008 9:28 am ET by benhasajeep
the ridgid is spossed to be amazing. I wish I had the money for one
"I'd rather be a hammer than a nail"
I have the Ridgid up north & have a Delta Boss here in FL. Like the Boss much better.
James
you have two shops? wow, ur lucky
I have a Ridgid oscillating spindle/belt sander that I replaced with a Shop Fox floor model spindle sander. The Ridgid is little used and in excellent shape. If anyone is interested I will sell for $100 plus shipping from Columbus, Ohio. I have some extra sanding sleeves and belts that I will throw in also.
Bruce
I sent a note via your email Bruce. I just thinking of how I could finagle one of those.
David B
too steep for me, sorry
electricity entices me
I never use one to sand straight/flat pieces. These sanders will unassumingly form little hills and valleys quite readily. But, to each his own.
I've got the Ridgid Oscillating Belt/Spindle sander. I never liked sanding. I still don't like it, but don't mind it as much. The belt feature is very useful and I would highly recommend the Ridgid.
Chris @ flairwoodworks
