Hello to All,
I’ve recently bought an old bandsaw but there’s a feature that I can’t figure out. There is a sliding table mechanism that moves the table left or right. Naturally, it can’t go very far because of the blade. It’s the first time I see this on a bandsaw.
Does anyone know it’s usefulness?
Thanks to All,
Rehab.
That feature allows your bandsaw to reflect your political orientation. ;-)
Rehabhog,
Some pics might help, sounds strange.
Tom
Space saving maybe?
and www.flairwoodwork.spaces.live.com)
Maybe it allows you to clean out dovetail waste.
Thanks for the Replies,
I want to do some restoring on this saw before putting it to use, so the answer should pop up at that time. I think it might have something to do with the way this saw tilts but won't try that until it is bolted to solidly to the floor of the yet to be built shop. My curiosity will have to wait.
Rehab.
I noticed a sliding table on the bandsaw in a local butcher shop. They were cutting pork chops. However the left-right matter is a puzzle. The one I saw had its table move to and fro.
Any chance you could give us the brand and model number of the saw?
Shop Manager for FWW Magazine, 1998 to 2007
Hello,
I found the answer on the owwm site trough a web search. It's an angle bandsaw on which the whole arm pivots but the table stays horizontal. The table is suppose to slide as the frame tilts allowing the point of cut to remain the same. This wasn't obvious because a large carriage bolt was inserted to lock the frame in place even though the table still slides on my saw.
Just to end the tread, the saw is a 36'' Crescent angle saw made somewhere in the 1930-40's. Much older than I would have thought.
Thanks to all that have pondered this question. It's much appreciated.
Rehab
Also known as a “shipbuilders saw” I believe, very useful for cutting the changing bevel on a hull frame.
If you haven't run across the site already, you might check out the Crescent pages on the Old Woodworking Machine site:http://www.owwm.com/mfgIndex/detail.aspx?id=224&tab=0You might even be able to contribute some additional information.
Quick way to correct for blade drift?
