paint grade built-in material (not MDO)
I’m getting ready to build a set of built-in shelves that will have a paint finish. I normally don’t do paint-grade work, but a couple of years ago I used MDO on a project and it worked well. Well, I checked the price of 2-sided MDO from my local plywood supplier and they want $80 a sheet! You can buy nice birch or maple for that price! I’m thinking of using MDF (all the edges will be face-framed) but are there any better alternatives?
Dave
Poplar?
I will probably use poplar for the face frame. The local plywood supplier has a decent birch ply for about $42/sheet. I really liked the MDO for paint-grade work the last time I used it. Guess I forgot how expensive it was. I vaguely remember reading somewhere that it's used a lot for signage, probably because it paints so well.
Dave ,
Along with Poplar or Soft Maple for the face frames , often times I use Maple shop plywood . The Maple veneer seems to be less fuzzy and smoother in general then Birch , for about the same cost.
dusty
"I vaguely remember reading somewhere that it's used a lot for signage, probably because it paints so well." Yep, and it's also pretty weather resistant.forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)Another proud member of the "I Rocked With ToolDoc Club" .... :>)
Unless I am concerned about water damage I use MDF. No wood grain will show through. Other than that Birch is OK, I generally prime with two coats of shellac (Zinzer BIN) sanding in between with a block. That levels out the finish so no grain shows.
Poplar is good, but in my area I can buy brown maple for the same price. I find brown maple to be stronger, and is harder to dent than poplar.
Machines better too.
