Last evening my Uncle gave me an old jointer he had out in the barn. After getting it home, I cleaned the rust and grime off of it and fired it up. It seems to work fine, but adjusting seems a little confusing for a new guy.
The jointer is a 4″ Delta Homecraft. That is about all of the info I could find on it. All parts are there and are functional. Any advice, hints, tips on it’s use and adjustments would be appreciated.
After a bit of research, it appears that the planer in question is a Delta Model 37-290 of the 1950's.
I had that same machine for a while. Sold it last fall. Log onto
WWW. OLDWWMACHINES.com for more info.
I've got one of those!! Been using it almost 20 years. Fine little machine. Call the folks at Delta (1-800-223-7278). They will probably be able to tell you what year it was made and send you an owners/operators manual or a parts breakdown; maybe both.
Sharp knives and accurate adjustment will make that hummer work like a dream. Only thing is the short bed. Not good for large boards. Stick to short stock for a while until you get the feel for how it's supposed to work. Enjoy!
Mack
Edit: For an excellent and very practical explanation of all the required adjustments and shop-made tools for doing it; see the book:
"Care and Repair of Shop Machines" by John White, Taunton Press ISBN 1-56158-424-X
Mack
Edited 1/26/2004 6:06:45 PM ET by Mack
