Can someone tell me what would happen if I wiped-on a brush-on finish? Specifically a water based polyurethean. What negative affects would come from it?
Also, I’m looking for a wipe-on protective finish that will not tint white oak. I want to keep the white oak at its natural hue and tone, as natural as possible, not adding any amber to it at all. Any ideas?
thanks
Wipe on finishes are quite dilute--50/50. The ordinary brush on finish would be too thick to wipe.
I've wiped on full-strength water-based finish, both Minwax Polycrylic and General Finishes High Performance Poly. It works fine, water-based finishes are rather on the thin side anyway. As was pointed out to me a little while ago, the "feel" of wiping on is entirely different than wiping an oil-based finish. The water-base kind of drags on instead of gliding on.
Water-based finish of this sort is probably as close as you'll come to the look of no finish at all. I have a test piece of Ash at home with a light wipe-on like this, and to tell which piece has the finish I have to touch it.
Dave
You can use a waterborne finish right out of the can as a wipe-on. Do not thin it any more than recommended on the can. Thinning will destroy waterborne finishes.
