Jet dust collector switch problem
I have a Jet 1100 CFM dust collector that operates on 220V AC power. I want to put the unit in an enclosed area outside my shop and I am wondering how to deal with the switch. There is a switch on the unit now……..should I remove this switch and mount it inside the shop with a dedicated power supply and then run leads out to it or should I just leave the current switch in the “ON” position all of the time and plug the power supply cord into a 220 V AC supply with a second switch on it? I don’t know much about electric motors and I am not sure if leaving the switch in the on position will impede any “starter” type function that may be built in. On the other hand, I am not anxious to start dismantling the existing factory switch if I don’t have to. Thanks for the help………bill
Easiest choice is to by a remote control and just plug it in.
Second easiest is the seperate switch in the power line.
I wouldn't bother taking the unit apart, easier to do one of the above.
I would think that you can leave the existing DC switch on. To be sure check the owners manual or check with jet direct. For a handy remote control switch Check this site out:
http://www.dnet.net/frnbrook/shopgadgets.htm
This is the basic system that is sold with the oneida DC system.
Our shop has 3-phase electric, so we had to do some modifications to the basic remote control system to get it to work. On standard single phase 220v electric this should work.
The remote transmitter is about the size of a car remote control and can be easily attached to your shop apron.
If you do use this remote, make sure you have a disconnect switch when you are not working in the shop. (I just turn the breaker off)
Hi Unisaw,
I did a search and found your post about adapting a dust collector remote control to work a 3 phase Dust Collector.
I am installing a 3 hp 3 ph Onieda and would love to know how you adapt the remote to work with the 3 phase collector. My remote is currently rated for 220v use.
Thank you in advance!
Tom
Our dust collector is 2 hp single phase 240volt. It was installed about 2 years ago.
For some reason the standard 240v plug-in relay /receiver would not work because of the 3phase wiring in our shop.
Onieda referred me to Fernbrook (see link above) and they sent me a 3 phase relay switch that is triggered by the wireless receiver. The receiver in turn is operated by the wireless keychain transmitter. We only use 2 of the 3 contactors in the relay, so I would think that this same set up would work with a 3phase 3hp motor.
This system has worked well. The only thing I would change is to have a fixed on/off switch in the center of the shop, probably at the table saw. There are times when I can't find the remote because it is hidden in a pocket somewhere!
I deal with Linda at Onieda She is very helpful when she is not on the phone!
Find out exactly what kind of 3-phase wiring you have, and I’m sure between Onieda and Fernbrook they can get you set up. As always use a qualified electrician.
Here’s a picture, It’s not very good, but it may help. JJ
Dear friend,
By codes and common sense, a LOCAL means of disconnecting the motor is what's called for.
Local disconnect means any one accessing the motor can turn the power supply off, for his own safety. Else, anyone handling the motor could be shocked or hurt by an unexpected start, since the disconnect means are out-of sight, or too far away,
If you remove the switch and relocate it, you could put a receptacle and plug in its place. That'd be a more positive indication that it is disconnected when working at the motor, or when emptying bags, for instance.
-mbl-
