Is minwax’s pre-stain wood condition the same as a 1lb cut shellac?
I have stained a set of shelves and now want to seal the colour before applying a top coat of a wipe on Oil-Varnish blend. I have read that a 1lb cut shellac is a good initial sealer before applying the protecive varnish or oil finish coat. Should I use the Wood conditioner as though it were a cut shellac so that I dont ruin the stains colour or am I being paranoid?
I used the wood conditioner to seal the pine before I stained and am happy with the results. I dont want to wash off or rub out any of the colour. I don’t have any shellac but do have most of a 1 litre can of Conditioner.
Cheers,
“Almost Finished…”
The wood conditioner does not seal the wood, but allows more uniform absorption of the stain on especially soft woods. It is not a shellac product. First, read the contents on your pre-stain conditioner. It will probably say mineral spirits somewhere and will smell like mineral spirits. A 1lb. cut of shellac should smell like alcohol. My take on those that I have used is that they are mostly mineral spirits and my recollection of the one's that I have used have directions that say to apply the stain within 5-15 minutes or recoat.
Another point on top coating oil stains - let them dry really well - like 24 hours or you will be dissolvng stain with the top coat. You then have to be really careful not to get visible streaking in the stain coloration. I have found it necessary to wipe off the stain coat well, then allow 24 hours and add a fan to move the air around. This I am sure changes with temperature and humidity.
Jerry
First, if you used Minwax Wood Finish oil based stain, there is no need for a "sealer" coat. Any finish can be applied over it directily as long as the stain is fully dry.
Second, an oil/varnish mixture finish should be applied to bare wood. It is intended to be absorbed into the wood, not sit on top of it. An oil based stain contains a small amount of varnish and the varnish will, at least partially, seal the pores of the wood affecting the ability of the oil varnish to be absorbed. Applying a coat of shellac will completely seal the pores and none of the oil/varnish will be absorbed. When you wipe off the excess oil/varnish, you will wipe off all the finish.
At this point, apply your oil/varnish using a pad of 4/0 steel wool. Rub in the direction of the grain and rub very lightly. Let it set for 15-20 minutes and then wipe dry. Let it dry overnight and do it once more. That should do it.
