Filling large inclusions in splated wood
I have a couple of nice bookmatched spalted birch boards. However, both of them have two large (3″ + )inclusions (really big, loose, soft knots) that I need to fill/stabalize before doing anything with it. The pieces were air dried and in conjunction with the spalting the wood is fairly soft so I’m going to use Pentacryl for the whole piece, but I need to know how to fill the gaps in the inclusion? Epoxy? Thanks.
(3" + ) is pretty big! especially for a book match..
You never stated what you wanted to make.. Some sort of inlay for 'effect'?
Edited 12/5/2005 7:24 pm by WillGeorge
Along the same lines as Will's 'inlay for effect' idea:
I've had some 1/16" slices of polished rock for some time with the intention of eventually using them on something like your 3" void. My idea was to give it the look of a tree that grew around a rock. Haven't found the right piece of wood to use them on yet but I thought they'd look more interesting and more natural than a dutchman type patch. I think I'd leave a fraction of the void visible and fill with black epoxy if I ever get around to doing it - just so it looks like the wood separated growing around the rock.
Just a totally left-field idea, but I thought I'd throw it out there.
If you build it he will come.
The tow bookmatched pieces are to be joined together and make a semi-circular table about 17" by 21". The inlusions are right at the intersection of the boards. I'm hoping that the stabalizer and some black epoxy will do the trick.
Rocks and wood: A few weeks ago, some of us WWA members entertained a woodworker from England while he was visiting Seattle on business. At one of the galleries was a beautiful cherry coffee table with bookmatched waney edges running longitudinally in the center, leaving an elongated ()-shaped hole in the middle. The creator filled that with smooth, small (1"-2") river rocks. It was really pretty and kind of meditative the way it was done. The rocks weren't fastened in place, but very carefully arranged.forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)Another proud member of the "I Rocked With ToolDoc Club" .... :>)
AND What did the English Man say at that one?
Hi
I have a dumb question, what is [pentacryl]? Is ir something to harden soft spots in spalted wood? Where di i get it?
Have s nice day Lee
Lee - Pentacryl is a stabalizing compound that you soak or brush onto wood. It replaces moisture with an siliconized polymer. It's mostly used for turning green wood. Just do a google search on it.
Hi Nokogini
Thanks for the info. I learned something today.
Have a nice day Lee
