Hi Gang,
I’m putting together a shop with some neighbors. One of them has an old, old, 3-phase Unisaw. Judging from the logo graphics and such (Rockwell Mfg. Co./Delta) it could very well date from the 40s or 50s. It has no dust port, just a door with a knob at the top, much like the saw pictured here:
http://www.owwm.com/MfgIndex/detail.aspx?id=1141
The door is a shade under 12×9 inches. Does anyone know of a dust port that fits this opening, or do we need to fabricate something? (That wouldn’t necessarily be a big deal, as the owner also has a metal shop, but if there’s something out there it would save some hassle and time.)
Thanks!
Ted
Fine Woodworking Recommended Products
Drafting Tools
Add a hole guide to this kit, and you'll have the tools you need to work out your designs with scale drawings.
Triton TPT125 Planer
Accessing the knives on the Triton for changes was not difficult, but getting the knives out was tricky, because no magnetized handles were provided to lift the knives off the cutterhead. There is a 2-1/2-in.-dia. dust port, and chip collection was good when hooked up to a shop vacuum. The housing has an open top and just one return roller on top, making it impossible to stack boards there in between passes through the machine. Also, there is no gauge that indicates how much material you are removing in a pass, making it one of four planers that don’t offer this feature.
Bora NGX Clamp Edge System
The NGX Clamp Edge System from Bora promises to deliver all the functionality of a proper track saw using the garden-variety circular saw you already own. The five-piece Deluxe set includes the sliding saw plate, the 50-in. Clamp Edge track (with built-in edge clamp), a 50-in. extension track, two specialty clamps for angled cuts, and zero-clearance plastic strips for both tracks.
Makita 2012NB Planer
Of the planers with two-knife cutterheads, the Makita produced the best surface quality. The knives are very narrow and a bit tricky to change, but Makita provides two magnets for lifting them off the cutterhead, and these make it easier. The machine’s dust port is an odd size, with an outside diameter of approximately 2-7/8 in. I used an adapter to connect it to a 4-in.-dia. hose, but dust collection was only fair. Finally, a full revolution of the height-adjustment wheel moves the cutterhead 3/32 in. The other machines move 1/16 in. with a complete revolution of the handle, a dimension that’s much easier to work with because the most common thicknesses for furniture are in multiples of 1/16 in.
Genesis GBS321 Belt Sander
Weight: 7.8 lb. Amps: 8 Variable speed: Yes Belt alignment: Excellent Material removal rate: Good Sanding flatness: Fair Shaping/scribing: Very good Handling on side: Good Dust collection with hose: N/A
Ted,
If you do some searching in the for sale section (they call it "Bring Out Your Dead") of OWWM you will find instances of dust collection pans that someone fabricates and sells for unisaws. I recall that it looked like a slick solution to dust collection for one of these saws, but I don't remember much more about it.
Is your neighbor's Uni one of the four footed models as in the link you provided, or does it have a solid base around the bottom? Those four-footers are considered the primo models by the collectors. Also, somewhere on OWWM you can find a table that will tell you the year of your saw if you have the serial number.
Jerry
I have an older Unisaw, 70s methinks that looks a lot like the one in your pic. I used a plate from Western Tool Co. that is made to go on a jointer. However mine replaces a plate that was on the back of the saw.
I'm in the process of adapting mine so am interested in what you find here. I also cobbled together a box that has heavy felt on it for the motor and am trying to come up with a blade guard/DC connection.
Trouble with these older machines is that they weren't originally designed with dust collection in mind so sometimes ye got to use a wee bit of injinuity!
Bob and Ted,Try this link: http://owwm.org/viewtopic.php?t=47360&highlight=unisaw+dust+panJerry
