I need to know the best way to change a gloss finish to a satin. I refinished just the tops of two bedside tables, sprayed several coats of Deft, hand-rubbed them and polished with automotive polish, then I forgot they were supposed to be Satin! The wood is a dark brown mahogany so any little scratches and streaks show up easily. Should I rub it down with 0000 Liberon steel wool and wax or just re-spray it with Deft Satin???
Thanks for any help
If you still have enough finish that you aren't in danger of cutting through you can use a coarser rubbing compound and pad to go back to satin. Steel wood also works but often gives a bit more visible scratching. If necessary you can spray another coat of gloss, but may have to do a bit more leveling depending on how smoothly the coat goes on.
Spraying with satin also works, though you may have to buy more material, and unless you are happy with the off the gun results might have to rub out anyway.
Steve's advice is good. But be aware that a rubbed out satin will look different from one that is a satin (in the can) finish. As always, it's best to do sample panels so that you can see and judge for yourself.
Personally, I can't seem to rub out a gloss finish to look like a sprayed (or wiped) satin finish. It always looks too glossy although covered with tiny scratches. Whereas a rubbed out "satin" will look like a non-glossy finish. Now all that probably makes no sense at all without actually seeing what I'm looking at. Do some sample boards.
Hello Geppetto,
With many sprayed finishes, the normal method of arriving at a satin finish is to first apply a few coats of gloss finish, which has a higher solids content and therefore will build faster. Fix any problems ie. dust specks with a light sanding with 400 grit or higher. Spray the final coat with the satin finish. As others have said test on scrap first.
Bob, Tupper Lake, NY
Just a quick point. "Solids", used in the context of finishes are anything left in or on the finish that does not evaporate. The flatteners always remain in the finish so they are considered "solid". Non-solids are thinners and solvents.Howie.........
