I have the excellent Bosch jigsaw — top-handle model with the pestilential plastic tool-free blade change. The only problem I usually have with it is the “Clic” handle coming off in my hand when I change blades. At the moment, though, the plunger into which the blade fits is jammed — I can’t push up or turn it. Does anyone know of a quick fix, or do I have to lose it for a couple of weeks in the repair outlet? I rarely use it in fact, but right now I’m in the middle of cutting block-front drawer bottoms whose size makes them awkward to cut on the bandsaw — and the new Bosch blades mean I can cut to the line with no sanding. ( They do a great job, but seem to discolour instantly into a horrible shade of puce, even in poplar — doesn’t seem to affect performance, though.)
Jim
I have a Bosch as well. Seems to be you have to pull up on the plastic handle, then turn it counterclockwise to release the blade. I you don't pull up far enough, it does not work. I admit my handle is still attached so that may be your problem. Try to find a temp solution to keep the handle attached, wedge, super glue etc then get it fixed after your project. Best of luck.
AZMO
-----------_o
---------_'-,>
-------(*)/ (*) http://www.EarthArtLandscape.com
Thanks for the input. The removable handle is just a nuisance thing -- replace it and it usually works. Just in case it was the problem I tried turning the ratchet underneath with needlenose pliers, but no joy. The plunger won't turn, though it moves up and down when you power up. Time for a visit to the tool hospital. Maybe I'll go fully neander and use a fretsaw in the meantime.
Cheers, Jim
I have the old style,but I might have a clue to the problem. With my barrel handled saw their is an orbital option.Their are three settings. Push the lever to the third setting.Now the plunger will push up and turn. As far as the plastic handle ,Mine falls off once in a while.I just push it back on any old way it fits.
mike
Thanks Mike. Already tried that, and it didn't work. The parts sheet shows a couple of springs in there, one inside the other, and I'm guessing they're caught up. Any time I open up a machine with springs inside they end up at the other end of the shop under a pile of sawdust, so I guess I'll pay the pro.
Jim
