1725.1 | |
My 18 year old skil saw finally shot craps. Like most woodworkers I only need a circular saw to cut sheet goods. I recently purchased an 18 volt Dewalt drill/driver. I need a circular saw and wondered if the 18 volt Dewalt trim saws have enough power to cut 3/4″ plywood or 4 quarter stock . Will the 18 Volt Drill/driver batteries work with the trim saw? |
I do belive that DeWalt has universal batteries
"It is like hitting yourself in the head with a hammer: it feels so good when you stop"
My 18v. Dewalt batteries fit both my saw and drill. The 18V. saw will cut 1-1/8" T&G ply subfloor without a problem. I built a 10"x10" shed using the Dewalt to cut all the sheetgoods, with 1 battery on the charger and one in the saw or drill.
I have the 18V Ryobi and have cut 5/4 poplar with it. It's great for quick cuts I don't want to drag the 7-1/4" saw out for, or for cutting things like Masonite where a lighter saw really helps. I would think if the Ryobi cuts pretty well, the DeWalt would cut better!
There are 2 different 18V DeWalt circ saws. I have the "compact" version (DW936K) that uses a smaller blade (5 3/8"). I like the light weight - it's very handy to grab and cut something. There's not much variety in the blades that are available, I've only found 2 DeWalt's that fit it. There may be a source for them online, I haven't checked. Also, while it will cut through 2x studs and 3/4" plywood pretty well, the battery won't last very long. I'm not sure that I would buy one to replace a corded circ saw, but it is a nice addition.
Their XRP version (DC390K) is larger and may work better as a corded replacement. I have an 18V NiCad Milwaukee that is worthless, the most I can cut with it is cardboard footing tubes or foam sheathing, and it weighs a lot more than the DeWalt. I have used a Ridgid 18V (Fuego) that worked well and also uses their 24V and 18V LiIon. May not be worth buying a whole new Battery system for, though.
You may want to check on Ebay and other online sources for bare tool DeWalts. A lot of people sell off tools from a kit that they don't want. Seems like I saw some pretty cheap on there.
Jamie
I so the ones on Amazon for 49 + but I guess I will have to buy a new corded one. Thanks
For Xmas, Santa (cleverly disguised as my daughters and SIL), gave me the Ryobi 18v Li-Ion tool set. I've been using it heavily for a month now and am more than impressed with it - particularly the circular saw. It goes thru 3/4" ply with ease and I can make lots of cuts before it runs low on gas.
I suspect that you would find the 18v DeWalt just as handy. Since you say that you recently got the DeWalt cordless drill, I would bet that the saw would use the same battery. I don't think that any of the major cordless brands make unique batteries for each tool in their lines. Interchangeability is the name of the game and I believe that DeWalt also lets you use either Ni-Cad or Li-Ion batteries in the same tool.
