I recently bought an old used workbench, thats in pretty godd condition except the tail vise.
I taken in apart, cleaned it and greased the skrew with Tallow.
The problem lies in that I can´t get the faces of the vise flush, it´s worn down more towards the benchtop, so it will not grip good.
Is tyere any good ways fpr flushing the vice faces?
I tried to attach plywood faces, but it wont do the trick.
> Is tyere any good ways fpr flushing the vice faces?<
Ess, thor r
worn faces
You'll either need to remove the faces and plane them flat, or add a solid wood supplemental face to each side that can be planed to compensate for the wear. Shiming the supplemental faces might also work, depending on the nature of the wear.
Don't be afraid to search this site before posting questions
http://forums.finewoodworking.com/fine-woodworking-knots/general-discussion/wood-vise-toe
