I just finished building a workbench (my first real woodworker’s bench!)& I was wondering what finish I should use for the top. It is MDF. The legs/stretchers are pine. Thanks.
Personally, I don't finish
Personally, I don't finish work benches, but if you must I recommend an oil/varnish mix. NO FILM FINISH.
Some recommend a oil/wax mix. Personally again, I vote strongly against wax. Wax makes things slide, and I clamp things to the bench to work on them, I don't want them to slide.
I will vote for the wax/oil combination. Linseed oil, parafin or beeswax, plus mineral spirits works great. Glue can be popped off easily and it can be reapplied from time to time as needed 9- if needed. Mine is done this way on sugar maple.
