I’m folowing a recipe for finishing from Jeff Jewitt’s Beautiful Finishes book. At one point he calls for #0000 used with Wool-Lube or Murphy’s Oil Soap, neither of which I have. I’ve never even heard of Wool-Lube. Until I can get out and get some Murphy’s, which might take a few days given the incoming snow, is there an alternative to either of these? Lesson Learned: Stock up woodshop before winter. Have all supplies imaginable and some you haven’t heard of yet. –jonnieboy
Steel wool for creating a satin finish can be lubricated with a variety of things. Wool-lube is a Behlen product made specifically for that purpose. You can also use ordinary paste wax. Soap or water with a little soap to break the surface tension will also work and give a somewhat different look. It is important that at the end if the process you remove the wax or soap with an appropriate solvent. You don't want steel shards remaining trapped on the surface.
Remember this is only a final rubbing out procedure. Using steel wool between coats, even synthetic steel wood, isn't a very good method since it doesn't level nearly as well as fine sand paper.
Oh no!
I just now saw these replies! I didn't get notifications and thought all of Knots had put me on "ignore."
I am so sorry not have acknowledged your replies.
-Jonnieboy
jonnie -
google Behlen Wool Lube. Available at woodcraft, woodworker's supply, klingspor's and - of course - Homestead Finishing.
Keep in mind that Jeff J is a finishing guy, and he writes books and teaches classes, and he owns and operates Homestead Finishing. If it is mentioned in one of his books, you will almost always find it, or its substitute, at Homestead. One spin might be that his book references push product sales at Homestead. However, my view is that he does his homework, figures out what and how, and makes available the products that he has found to work. There has never been any instance where I felt even remotely like I did not get good value for my purchases at Homestead, and I generally go there first to look for what I need.
Spot,
Thanks for the reply!
--jonnieboy
jonnie,
Petroleum jelly. Like bryl creem, a little dab'll do ya.
Thanks all. This is a great help.
--jonnieboy
