I am working with a new set of woodline WL-1361 roundover profile rail and stile cutters and am having a difficult time getting the bits adjusted to make the pieces fit together properly. It seems to be the mail roundover portion which is not fitting properly into the mating cove.
http://www.woodline.com/scripts/prodView.asp?idproduct=214
I tried removing both existing shim washers from the male roundover cutter (right, above) but I still can not get a proper fit.
Any suggestions?
I bought a Woodline set of Stile and Rail bits at the wwshow when it was here..I have the Miniature set..I had the same problem..I had to shim and re-shim a few times til I got the set where I wanted it...all the shims arent the same size either..so be sure you measure them..just takes some fudging with...Good luck.
JC
