I purchased some Poplar to make some shelves for an enclosed spice cabinet. Although I lightly sanded the boards after I applied the stain I discovered planer chatter marks.
Tonight I sanded all the stain off with 60 grit sandpaper with my palm sander. My question is how can I find out that all the planer chatter marks are gone without applying more stain?
Back to the sandpaper, I plan to re-sand the boards with 80, 100 and then 150 grit sandpaper before I re-apply the stain. How does that sound?
Finally, I am going to apply a coat of Poly.
Thanks!
Try wetting the wood and see what you get.
Bio
Stan,
Try wetting the board with denatured alcohol. It will let you see the detail without raising the grain and it will evaporate quickly.
One more step. After using your ROS through 150, complete the sanding process by hand sanding with the same grit as your final ROS sanding--ie. 150.
By the way, while 150 is general fine enough for most purposes, lots of people do sand to 180 or 220. Which you chose will have an impact on how the poplar accepts stain.
Wiping the surface with mineral spirits is a good way to check for problems like planer ripples.
Hi Steve,
Thanks for your recommendations. Help me understand what you mean by the term "ROS." Also, what is the benefit of completing the sanding process by hand?
There is always something to learn.
Stan Pearse
ROS random orbital sander. Most palm sanders are random orbital, though a few are still just orbital. Only a few pad sander--mostly 1/2 sheet sanders now have straight line sanding.
Orbital sanding, random or not, will leave some of the sanding scratchesrunning across the grain, which makes them much more visible when stained. The hand sanding is done always sanding with the grain. Such scratches are much less visible. The finer the grit the less important this is, but up to about 400 grit or so it still makes a difference.
Steve,
Thanks so much for responding. I really appreciate the information that you kindly offered.
Have a great weekend.
Stan
