I am doing a project that is made from walnut. However, this is my first project so I wanted to start with a wood that inexpensive; but have the same strength and would use the same technique.
If I stain it to look like walnut what would be the best stain to use.
Thank you for your reply.
Moataz
Personally, I would just start out with the walnut and be very methodical. Measuring very carefully etc.etc. Using the "Good Stuff" will go a long way in keeping you mind on the task at hand and build confidence. Not so confident? Build a prototype out of Yellow tulip (Poplar) using the same care as above.
What is the project?
Bruce S.
Edited 7/17/2008 1:48 pm ET by BruceS
