My run-in (so to speak) with my paint brush is causing me to reconsider attempting to move up to HVLP spraying. Lots of reading leads me to think that a conversion gun and a medium sized compressor is the way to go. (I need a compressor, anyway).
So far, the best medium sized compressor seems to be a 25 gallon, 150 psi, 2 stage oil unit with a 2 hp (15 amp) motor, pumping 8.6 SCFM at 40 psi for around $380.
My question is this – what’s the groups experience when it comes to adequate compressor flow capacity. Will 8.6 SCFM cut it for use with good quality conversion HVLP guns?
Mike D
I purchased a Fuji Mina Max 4 and love it. The problem with a compressor is water condensation; so you will need to filter your air. You need no filter with a complete HVLP system.
Match the compressor to the gun. The gun manufacturer will tell you what cfm is needed. Most guns will require a 3 hp minumum. Even then it will need time to catch up. There are a few guns that are rated for small compressors but the cost of the gun is higher. Go to http://www.homesteadfinishing.com for help.
Who makes a good 3 hp compressor? And, is it possible to pack 3 hp into a semi-portable compressor? I'll need to be able to move it from the basement shop to the garage - stairs involved here.
Mike D
Park it and run a hose to the garage. Northern Tool has some decent compressors. Rollaire, Quincy, Ingersol Rand make good compressors. You should be picking out the gun first before the compressor. Read the CFM at rated PSI to pick out your compressor. Many guns require 5 hp. That's why a lot of folks go with turbines.
Thanks for the recommendations, Rick. I'll research those brands.
Mike D
Check your local suppliers and see about service and parts locally.
You might consider a turbine powered HVLP. The warm, dry air has its advantages.
Hal
http://www.rivercitywoodworks.com
Hi Hal,
Since I want to spray water-borne lacquers for cabinets and latex for finish carpentry, the pundits all say that I really need a three stage compressor for good results without excessive thinning. That puts me at about a $1,000 for an AccuSpray or Turbinare. And I still won't have a compressor - which is a pretty useful tool.
So, while I haven't ruled out a turbine system, it seems to me that for about $700 I can get a good compressor and a really nice pressurized gravity feed HVLP gun, and when I'm through painting, still have a good source of shop air (which I don't have at present).
Mike D
Mike,
That's a pretty good plan.
I use a Graco G4 3800 to spray everything. I used to use compressed air. It is a professional unit that I think cost around $800.00. It does an amazing job. I use it to spray polyurethane and polyacrylic finishes without thinning. I have sprayed shellac and catalized lacquers with it, as well as polyurethane paints. It comes with many tips for use with other paints.
Just so you know there are options out there being used by professionals besides the two most common HVLP setups. You do need a compressor though. If for nothing other than blowing your clothes off at the end of the day.
Oh, by the way, I got mine by hinting about it for 6 months prior to my birthday.
Hal
Edited 10/20/2006 2:15 pm ET by Hal J
new balance mt10
Furthermore [url=http://www.newbalance574-jp.biz]ニューバランス 574[/url], them should not be pretty loosened that looks such as some may be using training companies that happen to be inducing her to be able to slop close to. Converging Bowerman's attention to good quality managing shoes along with the experience together with knowledge this high-quality/low cost products can be manufactured in China along with delivered on the Oughout.Ohydrates. Fit, Jordan 12 carries with it an unique design and style.
It comes in a great analog style that's an exquisite yellow metal deal with. At the moment, theJordan will be usual without requiring simply golf ball participants but additionally along with teenagers, functioning runners, sports people, and folks today and even players all over the world. This helps ensure [url=http://www.newbalance574-jp.biz]ニューバランス 996[/url] the legitimateness and excellence of a shoes, nevertheless for a lot cut price. Wood will be real wood when laminate floors is constructed out of industrial solid wood making this untrue whenever putting in hard wood floors.
It is a fact that you may be able to uncover their hands on shoes owned by distinct rates and is also an individual's job to obtain their hands on a low priced and also at ease athletic shoe [url=http://www.newbalance574-jp.biz]ニューバランス 996[/url] in the market which has no difficulties. As soon as the Shox happen to be on the rocks throughout, they have an inclination to remain supplemental satisfactory and abiding for further clients. The design I acquired "Stella" adds to our number. Khaki, tangerine, beige, environment friendly are the colors which might fit with children together with light tan, very hot red, fuchsia, yellow-colored together with olive for women. You will discover terrific jogging shoes regarding inexpensive charges.
Flywire Air Max Three-hundred-and-sixty, engage belly dancing real wood material as well as other details of a combination of the returning to actual shoes the very first time in accordance with the specifics of any unexplained lighting can be viewed wood clappers Flywire know-how dust with [url=http://www.newbalance574-jp.biz]ニューバランス 574[/url] natural leather bottom and top, plus Air Max 360 is a most recent advancements inside offered physical appearance. The reaction for this Nike boot is definitely the largest very good outcome. Certain surveys are definitely negative, nevertheless a minimum of this helps you a clue in regards to the important arguments to some specified item.
All around 1990 as well as Year 2000, inside the short lifetime of 12 years, Nike opens more than 15 Niketown shops which essentially additionally arrange their name around the throughout the world economy. For example certain peanut were designed by using ambiance weight lifters which will boost the convenience concentrations for people who [url=http://www.newbalance574-jp.biz]ニューバランス 1300[/url] are generally in a circle connected with exercising. couldn't relax perfectly together with the Catholic Irish populace. Preferably invest that sum stored to order yet another pair of custom boots or sneakers.
The actual regions which will obtain this content are generally: Armenia, Azerbaijan, Belarus, Atlanta, Kazakhstan, Kyrgystan, Moldova, Uzbekistan, Tajikistan plus Turkmenistan. Have on this kind of perfume with all your great laid-back apparel. Exactly how speak regarding the changing dynamics for raditional?Pagerank, When i for 1 have always been amazed at just how minor particular attention is paid while in the [url=http://www.newbalance574-jp.biz]ニューバランス アウトレット[/url] PR arena to be able to Website positioning and internet-based popularity administration. There isn't a alternative hockey musician exactly who invests as often determination in to the producing connected with his or her personal bank footwear.
With this year, you will want to shade your daily life when using the Max Ninety days? Since I own casual thighs together with filter sides I selected tella?and that is small increase that has a tear drop waist. Create as well as Son's developed the particular spiked lone. Although there exists this type of legislations on the market, that is certainly, new items are likely to be [url=http://www.newbalance574-jp.biz]ニューバランス 574[/url] highly-priced.
new balance mt10
new balance heidi klum
Similarly [url=http://www.newbalance574-jp.biz]ニューバランス 574[/url], it ought not to be pretty loose that appears including an example may be dressed in instructors which can be causing the woman's to slop about. Converging Bowerman's focus superior working shoes along with the experience and knowledge that will high-quality/low price tag solutions can be produced in Okazaki, japan together with mailed to the Ough.S. Fit and slim, Jordan 14 offers an highly sought after pattern.
It comes in the analogue pattern containing a tasteful precious metal face. Presently, theJordan can be normal with out simply just golf ball people and in conjunction with youngsters, managing sportsmen, sports people, and folks right this moment and also players from all around the globe. This particular promises [url=http://www.newbalance574-jp.biz]ニューバランス 996[/url] the particular credibility and excellence of any shoes, specifically an extremely low cost. Wood floor is actually timber though wood flooring floor is produced with technological innovation timber thus, making this false as soon as investing in wood floors.
It's true you will be capable of getting hold of shoes of diverse prices plus its ones responsibility for getting their hands on a reasonably priced together with comfortable shoe [url=http://www.newbalance574-jp.biz]ニューバランス 996[/url] in the market without any troubles. Once the Shox are usually on the rocks during, they have a tendency to get supplemental adequate in addition to abiding for extra customers. The fashion I aquired "Stella" words of flattery the shape. Khaki, citrus, light tan, environmentally friendly will be the colors which could fit males plus light tan, very hot white, fuchsia, discolored in addition to olive for women. You can get terrific jogging shoes regarding very reasonable price ranges.
Flywire Air Max 360, harness bouncing wood floor materials along with information on a combination of those back in actual shoes the very first time based on the information of the unexplainable lighting can be seen wood clappers Flywire know-how materials with [url=http://www.newbalance574-jp.biz]ニューバランス 574[/url] synthetic leather bottom and top, as well as Air Max Three hundred and sixty could be the hottest developments inside the displayed physical appearance. The reaction for this Nike athletic shoe may be the major superior impact. Several surveys are actually damaging, nevertheless at the least supplies an idea for the important objections towards a selected products.
All-around 1990 as well as 1999, inside the quick span of 13 age groups, Nike starts up over 15 Niketown shops that quite simply in addition arrange it has the subject about the around the globe market place. As an example a few peanut were made along with environment lifters of which enhance the coziness quantities for individuals that [url=http://www.newbalance574-jp.biz]ニューバランス 1300[/url] are during a circle for training. didn't stay very well when using the Catholic Irish populace. Alternatively commit that will amount rescued to obtain an additional number of custom shoes as well as sneakers.
The particular places that may take advantage of the material are usually: Armenia, Azerbaijan, Belarus, Atlanta, Kazakhstan, Kyrgystan, Moldova, Uzbekistan, Tajikistan together with Turkmenistan. Have on this kind of scent using your neat recreational clothes. With all the discuss with regards to the shifting mother nature connected with raditional?Page ranking, My spouse and i for example have always been astonished at just how minimal focus pays while in the [url=http://www.newbalance574-jp.biz]ニューバランス アウトレット[/url] Public relations arena to help Website seo and internet-based status control. There is absolutely no alternative baseball musician that spends just as much time and energy in to the earning for the signature bank shoe.
While doing this year, you could start to colour your lifetime while using Max Ninety days? Since I possess casual hip and legs along with narrow I decided tella?which can be decreased go up using a tear drop waist. Create along with Kids developed a rised only. Nonetheless there is this kind of regulation sold in the market, that is, new products are likely to be [url=http://www.newbalance574-jp.biz]ニューバランス 574[/url] costly.
new balance 490
Likewise [url=http://www.newbalance574-jp.biz]ニューバランス 574[/url], them should not be really unfastened that appears similar to one is being dressed in teachers that happen to be producing her to be able to slop all around. Converging Bowerman's care about level of quality working shoes and also the understanding and attention which high-quality/low value merchandise may be manufactured in Japan and transported into the You.Utes. In top condition, Jordan 15 posseses an distinctive design and style.
It's some sort of analog style who has a classy platinum deal with. Presently, theJordan is actually usual without requiring basically basketball avid gamers and also along with young adults, going joggers, sportsmen, and individuals now as well as players from all of around the world. That makes certain [url=http://www.newbalance574-jp.biz]ニューバランス 996[/url] this authenticity and excellence of the particular shoes, but also for a considerably price cut. Wood can be wooden although laminate floors floors is produced with engineering timber so this is not the case while putting in wood floors.
The fact remains you will be capable of getting your hands on shoes belonging to several price tags in fact it is your own work to have their hands on a low priced and also relaxing boot [url=http://www.newbalance574-jp.biz]ニューバランス 996[/url] you can purchase without any challenges. When the Shox tend to be broken throughout, they have an inclination for being added satisfactory along with abiding for more many people. The structure I purchased "Stella" comments our figure. Khaki, fruit, light tan, natural could be the colorations that would go well with boys together with light tan, hot white, fuchsia, orange in addition to olive for females. Yow will discover superb jogging shoes with regard to very costs.
Flywire Air Max 360, touch belly dancing wooden fabric along with details of the mix of such into genuine shoes for the first time depending on the specifics of a strange light sometimes appears real wood clappers Flywire technological know-how dust together with [url=http://www.newbalance574-jp.biz]ニューバランス 574[/url] leather bottom and top, and also Air Max 360 could be the newest innovations from the provided looks. The reaction of this Nike footwear is definitely the major beneficial influence. Many articles are definitely adverse, however , not less than they give you an idea in regards to the important objections with a specified product or service.
Around 1990 and also 2000, from the small lifetime of 15 age ranges, Nike unwraps through 14 Niketown shops which will fundamentally additionally put in place the concept with regards to the world-wide market place. For example many peanut have already been made by using environment weight lifters which enhance the relaxation degrees for those who [url=http://www.newbalance574-jp.biz]ニューバランス 1300[/url] are usually during a spherical associated with activity. didn't sit well with all the Catholic Irish populace. Preferably devote which amount of money rescued to obtain one more set of two custom boot styles or simply sneakers.
Any zones which will avail of the material happen to be: Armenia, Azerbaijan, Belarus, Atlanta, Kazakhstan, Kyrgystan, Moldova, Uzbekistan, Tajikistan together with Turkmenistan. Don this specific aroma with all your trendy informal attire. Tough communicate regarding the adjusting character connected with raditional?Public realtions, My partner and i for one am amazed at the best way little particular attention pays inside [url=http://www.newbalance574-jp.biz]ニューバランス アウトレット[/url] Page ranking subject to Search engine optimization and on the internet good reputation organization. There isn't any other field hockey battler who spends as often effort and time to the doing for his particular bank footwear.
Within this period, you will want to colouring your daily life with all the Max 90? Since i have currently have athletic thighs and leg plus small sides I selected tella?that is minimal escalate with a contoured waist. Promote together with Sons produced the particular rised lone. Although there is certainly this sort of laws in the marketplace, that could be, new items are often [url=http://www.newbalance574-jp.biz]ニューバランス 574[/url] costly.
new balance 490
