On my way back from home, I have just driven past a whole orchard of walnut trees which have been cut down. They are not very big, with log diameters up to 12″ and less.
Will it be worth my while to try and get hold of the owner and get a few for sawing into boards, or am I wasting my time with small walnut trees?
Willie
Central Valley California
Well, if you had them slab cut 2" thick you could then use your bandsaw to saw out about 10 or so 2" square turning blanks from each log. Do you have access to anyone with a lumber cutting band saw to do the initial slab cuts?
PlaneWood
No problem to cut them, I have a bandsaw with 12" resawing ability and if the log is too big, I start with a chain saw.
The big question is whether after a year or so, the boards from these smaller trees will dry without too much checking and warping.
Willie
Jellyrug,
Generally walnut trees that size have a LOT of sapwood. Probably 1/3 to 1/2 of the log. So not much usable yield from them.
Joiner's work is right, they'll have a LOT of sapwood which at this stage in their juvenile age makes them warp a great deal. IMO, unless the guy cut these down to clear property, he is a fool and has committed an almost criminal act. Walnut trees take 80 to 90 years to reach full maturity to harvest.
get 'em if you've got the room to dry them.
walnut is easily air-dried.
Don't worry about the sap/heart. You can make striking panels from those logs.....for use as table tops or doors or whatever.
flitch cut the logs and be sure to mark the boards in sequence and per log....say log A, board 1 - A1...
Thanks for all the advice.
I contacted the owner, this is a large orchard with several acres of walnut.
The trees are about 20 years old, but they were planted on agricultural land with a very high water table. Apparently this inhibited growth and productivity, as walnut does not like it's feet to get wet. He will be replacing these with Almond.
The trees are grafted with English Walnut.
I will get about six or so logs and see how it goes.
Willie
to prevent warping and checking, do this,
Sticker them up about 12 inches apart. make certain the stickers are dry and all the same thickness.. align the stickers so that they are directly above the sticker below(very important..) then make certain they don't warp by strapping the wood together.. use those cheap little ratcheting straps directly over stickers, snug everything down and a week or two later go back and resnug everything to gether..
Try to keep the wood out of direct sunlite, when sawing the wood try not to have the center or pith in any board...
FDAMPIER, was it you who posted in another thread about using those ratcheting straps??? I want to thank you! I've been wonder how the heck to dry short pieces of maple (2-3 feet long) from a tree that was cut in the neighborhood recently -- someone got to it before I did, so I couldn't get the 8' pieces I wanted. I'm going to try the ratcheting method and then stack the resulting units. Thanks again.forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)Another proud member of the "I Rocked With ToolDoc Club" .... :>)
I may have posted it but I can't claim credit. i learned that trick here, just passing it on.. It works well!
What kind of straps do you use, and how long are they?
Posted a picture of the Orchard and the logs. This is English Walnut, grafted on Black Walnut. Trees were 17 years old. Will be an interesting experience, the wood is of light color though, looks like 100% sapwood. Don't know if the color changes when it ages and dries, or whether this project will end up as firewood?
Willie
Hope you enjoy your firewood, ;-( It won't turn black or dark I missed where you said about grated english walnut, If you're looking for that black walnut look you can stain it and it will sorta look like walnut, if you squint on a dark night with the lights out... ;-) real black walnut has all these wonderful colors, purple, black, browns, and reds etc.. that are what make it so special (that and the way it works)
Heh heh heh heh.....
Well, would anyone like a few cords of free firewood? Bonus: the ends are sealed with latex paint too!!
Willie
The little bit of English walnut I've worked was lighter than black walnut, but darker than butternut (so called white walnut). The stuff I worked was very pretty, and had a nice ribbon stripe to the edge grain. I'd try to get as much of the area around the graft as possible, that should be really nice. It's a pity the trees are so small...
Good luck,
I brought some black walnut planks with me from Canada 6 years ago. They have been stickered since. Started using bits last year. Wonderful wood. Stable, easy to work and finishes beautifully with teak oil. By all means take it.
