I stumbled across some amazing walnut burl veneer a while ago and found a project I would like to use it on.
I an going to make some raised panels and veneer the flat part of the panel if that makes sense. My question is should I veneer first then run it thru the router or vice versa.
I have a feeling tear out is going to be a problem.
Thanks for the advice!
Fine Woodworking Recommended Products
Rikon 10-3061 10-in. Deluxe Bandsaw
The 1⁄2-hp motor has all the power needed to resaw at its maximum capacity of 5 in.
The saw has two speeds: 3,280 sfpm (surface feet per minute) for wood and 1,515 sfpm for soft metals and some plastics.
Milwaukee M12 23-Gauge Cordless Pin Nailer
This tool is designed for convenience. The battery and pins are easy to load, and the safety lock operates with the same finger you use to pull the trigger. The depth of set is adjustable, there’s a work light, and there’s a hook for hanging the tool on your toolbelt. A gauge lets you keep track of when you’ll need to recharge.
Dividers
Incredibly useful for laying out, setting equal distances, and comparing measurements, these are an essential tool for any furniture maker.
Triton TPT125 Planer
Accessing the knives on the Triton for changes was not difficult, but getting the knives out was tricky, because no magnetized handles were provided to lift the knives off the cutterhead. There is a 2-1/2-in.-dia. dust port, and chip collection was good when hooked up to a shop vacuum. The housing has an open top and just one return roller on top, making it impossible to stack boards there in between passes through the machine. Also, there is no gauge that indicates how much material you are removing in a pass, making it one of four planers that don’t offer this feature.
Finish-It-Yourself DIY 1500 Workbench
In my experience, tear-out is unlikely to be a problem if the veneering is done well and the ground machines nice and clean. Depends somewhat on the thickness of the veneer tho - is it commercial veneer, or shop-cut and thicker?
My approach, all things being equal, would be to veneer the solid panels (both sides!), carefully mark out the areas to be machined, use a sharp knife to cut through the veneer just a hair on the waste side of the final size, and machine up to the mark in a couple or three steps (for the first couple at least). You'll know, well before you get to the final finish pass, whether this is going to be easy or hard!
Malcolm
New Zealand | New Thinking
repairman,
I think your instinct is right. As gnarly as your burl veneer likely is, the prudent thing to do would be to raise the panels, then veneer. Cut the veneer slightly oversize, then trim to the edge of the field after the glue is set.
Conventional wisdom says to veneer both sides of a panel, especially if it's thin. I've gotten away with veneering just the face side of door panels, which are restrained from warping by the frame they are captured in. Not telling YOU to do so, just my experience. Have to make sure your frame stock is stout enough to withstand warping forces.
