I recently purchased a Crown burnisher.I was under the impression that a burnisher would have what a machinist would call a 32 finish or better. I would guess that this burnisher has a 120 finish or worse.Should I attempt to hone this burnisher to a smoother finish before attempting to put a hook on my scrapers?
The first burnisher I had was a Crown and it was softer than the scrapers I tried to use it on! Scratched up terribly and the scrapers just laughed at it. You could do better just using a top grade screwdriver shank. Better yet, get a piece of carbide. Best is a piece of polished carbide.
Screwdriver
This is what we use at college. A hefty screwdriver with the head cut off. Works like a charm once you get the knack.
This one works well. I have tried several
http://www.highlandwoodworking.com/cliftonhssscraperburnisher.aspx
Burnisher
Thanks for the advice.I tried using a screwdriver and it seems to work ok.I suspect that as my technique improves, it will work better.
That's what I thought to
Nah dude Nah
modern scrapers seem to be on the hard side. I am happy with that. I farted around with all sorts of rubby dubby things from the backs of chisels to engine valve stems. The carbide milling bits finally made it easy and consistent but I was cutting my fingers up on the business end of the milling cutters.
The burnisher I posted is hard, very smooth and consistent and easy on the hands.
I hope you have softer scrapers than I do. Also poorly made ( not flat ) scrapers are hard to roll an edge or stone off a shot edge so if it continues to be a problem be sure you have well made scrapers with the sides stoned flat all the way to the edge.
