The Woodcraft flyer has urethane bandsaw tires for 20% off. Any pros/cons on them?
John O’Connell – JKO Handcrafted Woodworking
The more things change …
We trained hard, but it seemed that every time we were beginning to form up into teams, we would be reorganized. I was to learn later in life that we tend to meet any new situation by reorganizing; and a wonderful method it can be for creating the illusion of progress while producing confusion, inefficiency, and demoralization.
Petronious Arbiter, 210 BC
I bought a set of urethane tires from Iturra Design a while back. I also bought cool blocks, zero clearance inserts, their improved tension spring, a spinner tension wheel and a tension gauge. Yes, I went a little nuts. Blades seems to stay centered on the urethane tires better and seem to transmit power better. The better sping lets me tension bi-metal blades better and the gauge helps crank the optimum tension for a given blade. The spinner tension wheel makes it easier to de-tension the blade when you're done and extending blade life. Since I'm de-tensioning the blade each time having the tires keep the blade centered is a big plus.
I did the same thing a few months ago and its worth it.I noticed a big improvement on my 14" clone.I tried using roller guides and I didnt like it,but one thing is for sure your blade grips to that sticky tire so much better so when you begin to get nervous about the motor bogging through some tough lumber its working and youll be glad.--Cheers.
I have read a lot of hype in recent years concerning bandsaw tires. Based on years of maintaining bandsaws in school shops, I have found that in most cases tires will last years without problems . I must point out though that proper adjustment of the blade and blade guides is necessary for this to happen. You should take a quick visual and audio check of you machine every time you turn it on. Keep your ear tuned to detect any unusual sound each and every time you use any machine. Also, make sure your blades are sharp with no kinks . Beware of any sparks around your guides. If the teeth hit a guide block it will dull one side and cause you to have problems controlling the cut.
