I posted a review about 4 months ago about my new 26 inch Woodmaster and was asked to update it after I ran it for awhile. I can only use one word and that is fabulous. I have run hundreds of board feet and it performs as good as a widebelt ,actually the quality is better in my opinion and I have used widebelts for years. This is a great machine for a 1 or 2 man shop. The sandpaper lasts a surprisingly long time if you use a belt cleaner. If I had a high production shop I would go with a widebelt because the belts do last longer but as far as quality of finish it is equal. The problem we had at the old shop with our bridgewood 15 inch open end was that dust would collect under the platen and cause a dip that was not perceptible until a finish was applied and then it stood out like a sore thumb,also the oscillating motion produced wiggles that seemed harder to sand out. Of course with any widebelt or drum sander you must hand sand.
I agree with your statements, been using the same for 6 or 7 years with great results. While it's not a wide belt it does provide an excellent finish with minimal RO work before finishing.
DJK
Sounds like you never had the platen working properly. You can go right to finishing with the platen. Widebelts without a platen and drum sanders leave small ripples somewhat like the marks left by a planer. I've been using SCMI and Timesavers widebelts in commercial shops for 30 years. Nothing wrong with Bridgewood tools at all but I don't think it was set up to it's best capabilities. Dust shouldn't be able to get under the platen. The oscillation actually gives a better finish. Drum sanders tend to leave more linear scratches and the oscillation blends the scratch lines better. I've also done a lot of work with metal using widebelt and stroke sanders. The surface finish is even more noticable with metal than wood.
I'm also a big advocate of the stroke sander. The best option for the small shop. Used you can get them for almost nothing and again you can go right to finishing without hand sanding.
Edited 4/11/2007 8:45 am ET by RickL
Edited 4/11/2007 8:50 am ET by RickL
In regard to the dust under the platen it might have been a dust collector problem but my boss never wanted to spend the time to figure it out. In regards to an oscillating sander hiding scratches better I disagree.My sander does not leave marks perpendicular to the grain,they are parrallel without the oscillating marks.In the final analysis I don't want to see any scratches from the sander so if they are parallel or not doesn't matter,the sander is meant to make it easier to do final sanding without using too many grits hand sanding or orbital sanding,which I know you are well aware of. I have used sanding master and timesaver machines and they do a fine job,like I said in my review for a 1 or 2 man shop the drum is great and does a comparable job. For a commercial shop it might not be practical.No offense but I used a stroke sander for 5 years and hated the thing. It took up too much space and certainly requires skill to use properly, as oppossed to putting in a machine.Edited 4/11/2007 12:27 pm ET by rompus62
Edited 4/11/2007 12:30 pm ET by rompus62
That is the dedicated sander? Did you consider the planer as well?
Best,
John
Sorry John,I didn't get any e mails that you replied. It is the dedicated sander,the planer combo has a smaller head for sanding .I would not recommend the combo machine it since the rep at Woodmaster said it will not do as good a job as the dedicated sander.
OK, Thanks!John
I have WoodMaster's 25" molder/planer. The drum sanding function is far and away the weakest accessory of the machine in fact I don't even use it. That said the molding, planning, and gang rip saw is flawless. When I get the money together I will be getting a dedicated drum sander from WoodMaster.
