I have one old (but not antique) dining table chair that has a dark finish that is not in good shape. The finish is worn in places and the upholstery is not repairable (but that I can do). How do I tell what kind of finish is on the chair? I would like to strip the chair and then paint it. Can someone help me with the details? Thank you.
If you are going to paint it don't go to the trouble of stripping it! Just paint it.
*Well, I started to. I used Latex Enamel on one area to see what would happen. The painted area doesn't look good. It has several bubble type spots and doesn't appear to be stable. So I assumed that whatever the finish was would have to be removed. Thanks for any information anyone can give me.
*Put a drop of alcohol on it and if it softens, it is shellac. If not shellac, put a drop of lacquer thinner on it and if it softens, it is lacquer. If not shellac or lacquer, it is varnish (could be other things if newer, but I doubt it for your chair). Most any stripper will strip old finishes. But, if shellac you may want to just scrub down with 2/3 alcohol (denatured) and 1/3 lacquer thinner, and if lacquer make that 2/3 lacquer thinner and 1/3 alcohol.You should be able to just give it a sanding, then primer, then paint. I would not use latex as my experience is that it will not hold up or look as good as oil based enamel. Go to a full service paint store and tell them what you are doing and they'll get you the proper primer and paint.Best of luck!- Rod Cole
*Linda, if you've decided that the antique has no meaningful value (making removing the finish acceptable) then strip the piece, sand with medium grit sandpaper and paint it if you want a painted chair.Methylene chloride based stripper ought to remove about anything, I think. It can be dangerous to work with on a regular basis. Take the recommended precautions on the can.
