I have been asked to build a 6′ round table with an 18″ turned maple base. I have turned my share of bowls and spindles and own a large lathe capable of turning the base size. I am looking for suggestions for coming up with suitable maple stock that is dry and ready to use. When I turn bowls I rough turn and then wrap up and typically wait a year to finish turn. The customer obviously cannot wait for green wood to dry…
You'd use an edge glue up of several boards maybe 2" thick to make a rough dimension, then turn. There should be a sawmill that sells dried rough lumber somewhere near you, wherever that may be.
Thanks-another friend suggested the same thing. Doing the math and making up staves out of 8/4 or 6/4-doing the glue up and then turning the shape. I guess cutting the angle I'll need will be with table saw rather than router bit-don't think I could find a tall enough bit for 8/4 work. thanks again.
Usually a base that large is coopered, the thickness of the stock depending on how much profile you're turning on the pedestal. You could use a spline near the inside of the coopered pieces, to keep it away from the turning detail, or you could do it like the old-timers and sqare one edge and angle "bird's mouth" the other edge. The angles take a little figuring, but it's not really hard to do.
