I happen to have a nearly endless supply of free Raw Tung Oil, in the unthinned state. What drier should I add to it. It doesn’t dry by itself. Maybe it does I gave up on it after two days.
Someone told me to mix the Tung oil with Linseed oil and something else for a good finsih. Does that ring any bells?
Stilletto,
Pure tung oil takes about a week, under most weather conditions, for a dry-to-the-touch partial cure, and IIRC, about a month or so for a complete cure. A 50% - 50% mix with mineral spirits or turpentine will speed the "drying" time somewhat, but the curing will still take about as long.
If you want a quick-drying finish, tung oil (or linseed oil -- raw or boiled) is probably not what you want to use (try shellac or lacquer, instead).
Beste Wünschen auf ein glückliches und wohlbehaltenes Neues Jahr!
Tschüß!
Mit freundlichen holzbearbeitungischen Grüßen aus dem Land der Rio Grande!!
James
I just need the oil to dry, not in a few hours or anything. I left it for two days and it still wasn't dry.
This oil is free and I want to use it on a few pieces I am about to finish. But if I can't get it to dry I'll need to find something else.
I just wanted to avoid buying more Formsby's when I had buckets of this stuff already.
Japan drier helps some. I finally gave up and switched to Waterlox. For me it's either that or shellac from here on out.
I was told that japan drier would work, I will try it out on a sample board to get the mixture right.
I have used Shellac or Tung oil for all my finishes in the past, now that I can get this oil for free I want to use it.
I appreciate the replys.
