I want to print some components full scale on my letter size Dell printer. The component size is 15 by 4 inches, so I’m using landscape rather than portrait mode. I can print the component from SketchUp but it insists on tiling the printout on six sheets instead of on two. I cannot find anywhere a way to reset the tiling. Any ideas?
Change the height of the drawing window so that the height:width ratio is close to that of the two sheets of paper you want to use. See also the following link. I described this procedure there.
https://www.finewoodworking.com/item/25890/printing-templates-two-approaches
The process I describe should work. It's worked that way since version 3 at least. Probably earlier but that's when I started using SketchUp and thus the beginning of my frame of reference. Would you be willing to send me the SKP file so I can see what you've got going?
SketchUp file not tiling well
Hi Dave:
Thanks for taking time with this - SketchUp file attached. Also I'm using Windows 7 64-bit.
Van
Part 2
Sorry - I meant to send one of the actual components I'm having trouble with.
Crossing posts. I'll take a look.
Take a Look
Here are screen shots of the set up.
First, I resized the screen to be a tight fit around the drawing.
In Print Preview, I made the settings. I haven't got a printer mapped to this computer which is why the printer displays as it does at the top.
The Print Preview shows the two sheets.
This is what I outlined in my blog post.
Which part of it are you trying to print full size?
One of the problems I see with your model is that you've got a number of parts all rolled into one component as if the whole thing is carved from a big hunk of wood. This will make it difficult to do anything as far as making construction drawings or patterns.
It works - Thanks
I had everything set as you suggested EXCEPT you have both check boxes "Fit to page" and "Use model extents" unchecked. I had the "Use model extents" box checked from when I set the scale to 1:1. Everything else matched with your settings. Once I unchecked the "Use model extents" box all was fine. Thank you very much.
The first attachment I sent in error was a partial model. But I have 23 components saved separately so that I can print those components when necessary. For example I printed a dozen of them at quarter scale in order to build a model first.
Again, thanks very, very much.
Glad that worked for you.
So if I understand you correctly, you've split your model into 23 different SketchUp files? That seems like a lot of extra work to me.
In reverse
I did it the other way around. I created components, then assembled them into a model. But I still have a lot to learn about being quick and efficient in SketchUp.
I think you would find it much easier to build the entire model in a single drawing, making components of each part as you go. That will greatly reduce the chances for errors and once you have a few components in place, you don't need to know all of the dimensions while drawing. You'll just draw things to fit. It will also save you time because you won't have to assemble the model since you'll be doing it as you go. Just make sure that you make a component of a part before you move on to another part so they don't end up being welded together.
If you want to see a couple of examples of building in situ as I describe, take a look at the videos at these links.
https://www.finewoodworking.com/item/22911/a-fern-stand-demonstrating-my-drawing-process
https://www.finewoodworking.com/item/24328/jeffersons-bookstand-another-workflow-example
If you watch close, you'll see that I make frequent reference to the existing parts of the model for creating other parts. In my mind, this is similar to the way I work in the shop. At some point in the shop I have to stop referring to a plan and take measurements off of what I've already made.
Thanks for everything
I cannot see the videos unless they are posted somewhere else on the web. I subscribe to the magazine but don't have a separate subscription to the forum, so maybe that's why. messnervan at yahoo
You don't need a subscription to the site to look at the Design. Click. Build. blog nor any other blog here.
Do these links work?
http://blip.tv/file/3023488
http://blip.tv/file/3216052
Dave
Yes thanks, they do
all set
Perfect!
