Made the Turkey day deadline by 70 minutes.
first chairs I ever made
Walnut is difficult to photograph without added lite.
Added the China Closet that I made 3 years ago.
Picture 15 is Pignut Hickory.
Learned plenty making the chairs.
Table has ash extension rails & oak main rails.
Now broke but wife has 1 damn expensive dining room set.
Added the Mission bookcase built this fall.
Nice set--I like it a lot. I like Frank Lloyd Wright stuff--very pretty.
Were the curved rails steam bent or template routed or bandsawn?
The rectangular chair must have made it easier for joinery as opposed to a trapazoidal design?
Did you design this yourself or use a plan?
the curved rails were template routed - I dont have a bandsaw yet.
I did these pieces first figuring they would be the most difficult with no bandsaw. It turned out this wasnt the case.
I found the most difficult was getting exact cheek cuts on the angled tenons.Funny you mention the legs.
They are not rectangular, but 1 3/4 closer in the back than front.
In the 'linked' article, the author states that the leg offset SCALED out to 4 degrees - so my prototype I cut at 4 degrees. The joints where not very good at all so I DID the MATH.
Author not so sharp - the leg offset is 3.52 degrees which all the tenons had to be.I modified the linked plan to get balance for a 24" high chair.
The legs sit on the same dimensions: 19.75 s-s front & 18 s-s back & 17 f-b. Chair is 53" tall.38 mortise & tenons per chair
my left index finger & thumb still dont have 100% feeling back in the tips I meant to thank Mike Hennesey & (I forget the other fellow that sent me a link to a chair plan) in my pictured post. So I will HERE.
Thxs to both of you. Needed only 1 prototype.
Edited 12/2/2008 9:41 pm ET by roqqytop
Nice work. But even more impressive is the fact that you got 8 chairs done, finished & upholstered in about a month! You must have more spare time than I do! ;-)
I'm glad you posted these -- I was wondering how those chairs were coming.
Mike HennessyPittsburgh, PA
thks Mike, but not spare time.
More like 8-10 hours for something like 11 straight days.Already started on the next project - a foyer lite that will replace the BULB pigtailed to the 12-2 thats been hanging there for the last ........................16 years. Been pacing myself!
No plan, but I do have a 54" wheel rim glued up though.
rt ,
That is a fine set of chairs and table , to be proud of for sure .
great work thanks for sharing
regards dusty
