Anyone care to offer some thoughts on the pros and cons of larger diameter table saw blades (14″-18″)relative to 10″? The obvious plus is increased cutting height. But if one has an excellent bandsaw, how important is it on the table saw? I can imagine that the lower angle of cut from the larger diameter might give a better cut, but that is in my mind only and may not have any foundation in reality. Also, with the excellent blades available these days, how could you get a better cut on a good saw?
The minus side seems to be a lot more blade exposure relative to possible injury and more blade deflection.
I have just acquired a Northfield #4 after twentyfive years of professionally using 10″ machines in furnituremaking. I welcome your thoughts. Thank you.
Todd
Hi! Accuracy of cut I believe is what you may be referring. A 10" blade will have less wobble than a 12", 14", etc. blade, even with blade stiffeners. There are other physical parameters as you alluded (safety, etc.), and others with more experience than I can answer. I'd use the larger blades only when the thickness of your material needed the extra size. Smaller, better saw blades are less costly too.
If your northfield is like the one I am familiar with it will have a 1 1/8 or 1 1/4" arbor, I am not sure if you can get a 10" blade in that arbor size. The northfield that I used had a 1 1/4" arbor and we ran a 16" blade, the other thing to remember is the kerf is more like .175" and not the .125" of a 10" blade.
Scott T.
You can always make the hole bigger. Making it smaller gets tricky.
The major disadvantage to a large blade is that they're a lot more expensive, and in a small shop you won't see much benefit other than increased cutting depth. But in a large production shop there are some advantages, first of all, the blade has more teeth thanks to the larger circumference, which means faster feed rates (noticeable with power feeders), or better quality cuts with a slower feed, more teeth also mean less frequent sharpening, and a thicker blade body and larger diameter arbor mean that the blade can stand up to heavier abuse. With a home shop you'd never see the savings, but in an industrial situation they are more economical to run.
For your saw I think a 14" blade would suit it best. I worked on a 20" Bauerlee, and most of the blades we used were 14", using a 20" blade is pretty scary (especially when you see it spinning 8" above the table). Your lucky to have such a nice saw!
