I am trying to find patterns for 3/4″ stock. I once had a sheet from an old pattern book and can’t put my hands on it. The sheet showed old styles that used to be made. The one I seek mostly was one called Boston. I believe these were old wainscot styles. I have an arched ceiling in my bedroom and want the wood to wrap around the arch. The 3″ pattern worked well and that pattern gave me the texture I was looking for.
I am also looking to have it milled in cherry and am searching for someone to do the millwork as well as a source for Pennsylvania Cheery. I have a Crown Pointe kitchen that I put in 20 years ago when I did installations for a local designer. I am moving back to my old house and want to do some updating.
Any help would be much appreciated. Thanks!
McKinney Hardwood in Texas has Penn. Cherry. They ship only by freight carrier, however, so it is usually necessary to pick up the material at the freight depot unless you make additional arrangements for local delivery. If you are not in the Southwest, however, a Texas point of origin may not work for you.
http://www.mckinneyhardwoods.com/
