I am trying to come up with a way to semi-mass produce wooden switch plates. Hand drilling, bandsawing, routering,etc… is too slow. Would a pin-router work or… ?
A pin router would certainly work. It's the predecessor to the CNC router. Lots on inexpensive small CNC units out there but I would see about having them outsorced and focus on marketing them. Laser is another option. You could engrave designs as well.
Thanks you the info... I thought about a cnc. could be market for one here. Do you have any cnc machines in mind.
Shop-bot, Techno Isel, are a couple. Do a google search for CNC forums. Sawmill Creek has a cnc forum as well as http://www.woodweb.com Should be ads in the hobby mags as well. http://www.talkshopbot.com/forum/messages/312/18691.html?1172795524
http://www.routerforums.com/cnc-routing/6497-cnc-router-machine.html
Look at the order your making each process in. Ie when you cut the hole for the switch, or socket, drill the holes for the screws, cutting the outer edge etc. The right order can speed things up.
I saw a post just this week on another wwing forum on just this subject. The poster had made some router jigs to make the plates. I'm sorry that I don't remember which forum it was on. If I see it again I'll post the information on this thread.
Might you be thinking about the outlet covers posted by Little Bear on WWA:http://www.woodworking.org/InfoExchange/viewtopic.php?t=18867
I think I would try doing the big rectangular holes differently, for instance drill undersized with Forstner and then finish off with router bit and template. Anything that involves using a scroll saw is going to take way too long for multiples.forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
FG, that's pretty cool, but you can buy these things for about three bucks apiece, IIRC. Seems like a lot of work to save only a small amount.
And the ones you buy have a metal sheet on the inside -- I assume that's required for safety purposes (otherwise, they wouldn't bother to put it on there and spend the extra penny), but ????
Mike HennessyPittsburgh, PA
While that may true, often the plates in the stores are only in maple or oak. Someone may want them in a different wood. I have some oak plates at home, but I have to say that there was no thought to things like grain selection when they were made. That's something that could be done with "custom" plates.
Mike, I was simply responding to the O.P. I don't make these myself. If I did (switch plates, not outlet covers) they would fancy, themed things, something I could charge money for. forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
Yep, that's the one. Thanks.
What kind of quantities are you talking about? The "right" answer depends on whether you're making 100 per year or 100 per day.
stacking your cut to size stock in multiples (6,8,10, etc.), drill through stack for mounting holes, bench mortiser set up to cut your "square holes" through the stack.....???????
this way you can use many ( different) species at once and do your punch outs at the same time.
...The unspoken word is capital. We can invest it or we can squander it. -Mark Twain...Be kind to your children....they will choose your nursing home....aim low boys, they're ridin' shetland ponies !!
