I am working on a simple end table and would like to try string inlay for the first time. Do you think it would look ok if I just tapered two of the sides of the leg or should I taper all four sides.
Thanks Phil
Thanks Phil
Tapered legs and string inlay
Both 2 side and 4 sided tapers are used depending on the furniture style. A simple table with a 2 sided taper and string inlay on the outside un- tapered faces should look fine. Taking a risk, trying something different is how we grow and learn. Go for it!
Tapers
The two-sided vs. four-sided taper question depends on design and where the table will be located, I think. For example, tables that will be located against a wall will often use a four-sided taper on the front legs, but two-sided for the back legs. Free-standing tables may look better with all four legs tapered on four sides, since the table will be viewed from various angles. The width of the inlay also relates to the dimensions of the legs, I'd say. Too wide, and the inlay starts looking clunky.
Well Done Ralph !
Shades of the old days here eh ?
Do I win a Bubinga workbench for good answer? ;-)
