I am in the process of making a couple of different projects, including paneling our Library. I am using Cherry plywood as my substrate and am manufacturing custom moldings using my W&H Molder. I have a significant amount (2,000 bf) of steamed cherry that I’m using for the moldings – I want to be able to match the colors before I finish the projects by spraying M.L. Campbell’s Magnalac pre-catalyzed lacquer. As you know, steamed cherry is much darker than the cherry plywood – what can I do to match the colors between the two? In the library, I’d like the finished project to be rich and dark – is there a staining process that I could use to achieve a consistent color between the plywood and moldings?
I look forward to hearing your recommendations.
Michael
Fine Woodworking Recommended Products
Microjig MatchFit Dovetail Fixture and Jig Clamps - 2 Piece
- Clamp Throat Depth: 2-3/8" - Clamp Capacity: 0 to 5-1/4" - Clamp Pressure: 595 lb. open at 4" - Minimum Dovetail Slot Length: 3-3/4" - Dovetail Profile for Clamp: 1/2" x 14°
Armor Pocket Hole Jig Model APJ14001
The jig’s primary design feature is that the depth guide on the drill bit is set when you clamp material into the jig, so it is always right for the material thickness (from 1⁄2 in. to 1 1⁄2 in.). A color-coded system of screws tells you which screw length to use for each material thickness. A starter set of screws is included. The jig and screw system work as designed, with the exit holes well centered in material of varying thicknesses.
Pfeil "Swiss Made" Veiner #11 Sweep - 3mm
•Square tang handle •Octagonal hardwood handle •Alloy chrome-vanadium steel
Diablo ‘SandNet’ 80 Grit Sanding Disc
Compared to other products, the SandNet 80 grit cuts slower. However, if you're working inside someone's home and need to start at this grit, you might want to trade speed for improved dust collection.
Powermatic PJ-882HH Parallelogram 8-in. Jointer
The Powermatic smoothed boards excellently. It has a plastic insert that sits shallow of the fence, where thin boards tended to catch when flattening faces. The Powermatic was the only model that uses a knob to adjust the angle of the fence—a nice feature—except that locking it caused the fence to move slightly, which made it tricky to square the fence. But when locked, the fence did not move. The 90° stop was easy to set but wasn’t reliable. The guard was finicky to install and would often not snap back fully after a board passed by.
MinWax...red mahogony..fix it right up.
I once made paneling that covered an entire room, including the ceiling. it was maple but I still had colour differences to contend with. I finished it with what I call "presidential cherry" here are the steps I took.
first I sanded to 220 as usual then I stained the piece with a custom stain similar to red mahogany from minwax. after the stain dried I sprayed on a coat of pre-cat lacquer, then did a light sanding to knock down the grain.
the panels at this point should be nice and smooth but pretty awful looking.
the next step was a sprayed on lacquer known as a Toner, or Shader. to go with whatever stain was chosen as a base.
do not sand this layer. it may take a few coats to get the depth your after, but the important part is to keep the colour consistent. it also helps of you have quite a bit of experience with spraying.
next is 3 coats of clear pre-cat lacquer sanding very lightly with say 300 grit.
here is a really badly taken picture of the result.
Custom Cabinetry and Furniture
http://www.BartlettWoodworking.com
i have had good luck making cherry ply and solid wood match by using ml campbell microton spray stain in orange as a first coat to even out the tone then spray regular woodsong red mahogany stain over that with a lacquer topcoat 2 coats is plenty with magna lac if you lay it down wet this technique comes from the front page of a ml campbell pamphlet for woodsong stains hope this helps ps you need to thin the microton stain do not use straight way to powerful
