I’d like to turn a vase about 8 inches long. If the bottom of the vase is held by my chuck at the headstock, how do I support the vase while hollowing out the vessel?
Do I use something like a Oneway bowl steady?
Rich
Rich
Rich,
The bowl steady won't do it. That only has two wheels and is meant to support the opposite edge from the side you are turning on.
You need a spindle steady which has three wheels that 'surround' the piece. Same concept but more parts. If you don't want to buy one and have a few skate wheels or such handy, it's not hard to figure out how to make one.
Good luck with it.
Thanks Andy, now I understand why the bowl steady is not effective. The spindle steady is the way to go. I think I saw David Marks demonstrate a homemade spindle steady with inline skate wheels. He attached the adjustable wheels to a large circular piece of wood about 24" in diameter, which was then secured to his Oneway lathe. I might give it a shot. Again my thanks for your help.
Rich
Yep, you get the idea. Plywood with a hole in the middle, some slots for adjustment of the wheels. That sort of thing.Andy
