I just was given a Stanley #12 scraper plane. What can you the brain trust tell me about this tool? It is missing an iron, but appears to be complete in all other respects. The rosewood handle is in great shape and it appears to have all its japanning. Is it worth the $ to buy a replace iron and put to work?
Dan Carroll
Dan,
I have never used one but you can read all about this model on Patrick Leache's site here http://www.supertool.com/StanleyBG/stan3.htm.
I would say it is nice item to have but there are other models which are superior.
If I came across one sans iron I would not try to buy a replacement- better to make one or two from saw blades etc and experiment with different thicknesses.
The box of tools I was given had about 1/2 dozen wooden molding planes, the #12 and a #80 shave (also a scraper). They were given tome by my father in law. We were visiting for his 80th birthday and beyond just a quick once over, I have not had a chance to look them over in any detail. It thought it was interesting that there were two different scrapers in the batch.Dan Carroll
Dan,
Replacement blades are available for both the #12 and #80 at very reasonable prices. I have one of each but honestly, I use them infrequently and reach for my card scrapers all the time!
If I had them without blades I would definately shell out the few bucks just to try them out!
Mack"Close enough for government work=measured with a micrometer, marked with chalk and cut with an axe"
Dan,
The #12 just needs a scraper. Find a replacement, or cut yourself one from an old handsaw and learn to burnish an edge on it.
Alan - planesaw
Dan
Here is a link to an article I wrote on blades for the #112, which is a longer version of the #12.
http://www.inthewoodshop.com/WoodworkTechniques/Thick%20verses%20thin%20112%20Scraper%20Plane%20blades.html
Derek:I recently found the LN version in nearly new condition at a garage sale, and have not used or set it. Do you recommend a hook? How much messing around with angle settings is required? Someone told me to set the plane on a flat surface with a dollar bill under the front, and set the blade to the surface. Does that jibe with your experience?Joe
Interesting article. I was looking at the hock replacement iron, but it is nice to know the LV will work. The #80 has a well used blade still in it, so I may give it a try soon. It will likely not be in the next couple of weeks as I have a trip set for Atlanta next week.
One question I have for you -- how do you manage to make a living working in child mental health and still get so much done in the shop? I have a hard time getting a project started in the shop and I work in higher education.
Dan Carroll
Dan:
If you can, while in Atlanta you should go to Highland Woodworking. You can probably pick up a scraper blade for your #12 and #80 from them. Here is their Website: http://www.highlandwoodworking.com
Good thought. I know Highland is in Atlanta, but just did not connect that with my trip. One of those 'dah' moments.Dan Carroll
