I am planning on building a wine rack from a plan and the plans says to use spray adhesive to stick a pattern to the wood. Looking through the forum it seems the only time people are using a spray adhesive is to permanently stick one object to another. Is there an adhesive that you can use to stick a pattern to wood long enought to cut that pattern? Wont the adhesive mar the wood? (make it darker or just plain sticky) Any help on this would be appreciated.
Many of us use 3M Super77 spray adhesive. I've used it often to bond patterns to wood for scroll saw work. Letting it get a big tacky (30-second wait) helps keep it from soaking into the wood.
I'm sure others will come along with more tips. Any residue will come off with mineral spirits. I can't remember if I tried other solvents or not. Naptha's handy because it evaporates so quickly.
When you say let it get tacky (30 second wait), do you mean spray it on the paper and let it get tacky before attaching to the wood or on the wood and wait before adding paper?
Sorry I wasn't clear. Spray the paper, lightly, and wait ~30 secs before applying paper to wood. You could try out some dummy paper on scrap wood before going on to the real project.forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
Thank you! I think I will try this out and see if it works for me.
3M Super 77 Multipurpose will work as fg suggested. It is widely available and is generally a good thing to have around the shop. Ideally for your purpose 3M makes a 75 Repositionable. I don't see it in stores much but you can get it from McMaster Carr. http://www.mcmaster.com/#catalog/115/3366/=42vz61
Edited 10/16/2009 2:08 am ET by ricky
Hot glue works in many cases
But be sure to spray the stuff outside. The fumes are not good for you and the overspray is a bother on things you want to dust.
Peter
Great. I didn't think of that. I plan on going to Home Depot to pick up the adhesive on Sunday and will get started on the new project then.
How big is the piece of paper you're securing? Remember, you'll be spraying a very light coat. Fumes may not be an issue, but sticky overspray -- yuck. I always seem to be using it when it's pouring rain outside, so spraying out there isn't a great option.forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
For this project, the paper is about 2" wide by 12" long. My wife just got home from Costco last night with some nice big cardboard boxes that might make a useful spray area for inside the garage. It has been pretty wet outside so I may take that route.
2"x12" -- that's pretty small, less than 2 secs of spray I bet, wafting over the paper. Better too little than too much, as you can always add, but licking it off is decidedly unpleasant, LOL!forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
