I’m trying to design a split pedestal extension table that begins as a 54″ diameter circle, and extends out to 16 feet long. This will require seven leaves, and is often referred to as a Reunion Table. I’ll be using jatoba, and realize that I have a significant engineering challenge here, due to the weight of this species. The Waterton Table Slide Company, in Wisconsin, assures me that the table slides needed for such an undertaking are indeed available by special order, but that I’m facing structural issues in the design that need to addressed, including the dimensions of the “bridge” for the center post, (hidden when closed) and the diameter of the split pedestal.
Such a table is available commercially, but, of course, the company that sells it does not sell the plans for building it. I greatly appreciate any advise or direction you may have for me!
C,
Thanks for your question.
Furniture makers are protective of their plans and ideas. We have a good discussion on the matter here: http://www.taunton.com/finewoodworking/Community/LettersDetail.aspx?id=29416
Per the design of your bridge, could you possibly upload a preliminary sketch or visual reference, so we can give you a good answer?
Sincerely,
Gerald La Starza
Fine Woodworking
C,
I talked with an editor about your table. The center post and bridge will be able to hold up all the weight of jatoba. Since the force of the table is coming directly down, the two elements do not have to be very thick. The height of the table will roughly give you the height of the post and the column that houses the post will determine the post's diameter.
This article may help you:
http://www.taunton.com/finewoodworking/SkillsAndTechniques/SkillsAndTechniquesPDF.aspx?id=2916
Good luck.
Gerald La Starza
Fine Woodworking
