I’d like to find a source for used carving gouges and chisels. Any ideas out there?
I see them at flea markets and antique shows. There are also tool shows around the country that I assume would have them.
Youy may want to sign up for Patrick Leach's monthly tool list for sale. He often has individual as well as sets of carving tools. They are not inexpensive but he usually has a good selection and it's much cheaper and easier than searching garage sales.
http://www.supertool.com/forsale/07jun.htm
If you are going to buy carving tools look at the harder steel and those with higher carbon content. Too high a carbon content will cause the tools to chip and loose their edge RC 50 - 62 are best. Also consider if you want a palm set or a mallet set. Consider the type of carving you want to do first. If you desire to do larger carvings go to the mallet set. If you want to do small handheld carvings then go the palm set route.
Carving gouges and tools that hold their edge will be much more rewarding in the long run. Also consider buying a strope for keeping them sharp. I sharpen mine with each use using a strope. They are easier to keep sharp rather then taking them to a grinder or a wet stone.
