I know there are a number of solvents out there: Naphtha, mineral spirits, lac thinner, denatured alcohol, ammonia, and I am sure there are many more… What solvent do you recommend to clean your sprayer after using a water based finished? Many labels say use warm soapy water, but do you use that in a sprayer?
Thanks!
pita,
Warm soapy water is fine to use. A drop of soap is enough. Also I'd do a second cleaning with some denatured alcohol to help clean the water and soap residue from the gun
Peter
Thanks! Will give it a try
