Hi —
I’m looking for a sharpening service for planer knives (15 inch) on the east coast (I’m in Virginia). Any recommendations?
Also — any thoughts on using a jig for sharpening jointer knives? Or should I send those out as well?
Dave M.
Hi —
Dave M.
Forrest Manufacturing in NJ. It could take up up to 2 weeks to receive the sharpened knives as they only have 1 person doing jointer/planer knives.
"Life is not a success only journey." Dr. Phil
Thanks Jerry --I was planning to send Forrest my TS blade for sharpening -- didn't realize that they did jointer/planer knives as well!Dave
I sent Forrest 2 saw blades and a 12.5" planer knife set yesterday. If I remember I will let you know how long the planer knives take.
I have the makita wet sharpener. Works great!
That's an idea. I have used the fence on the jointer and sandpaper on the bed to sharpen scraper blades at a 45 degree angle -- I could use the same system to work on the knives.
On the other hand -- I am sending the TS blade to Forrest. . . .
Dave
Veritas (lee Valley) also makes a jig which works for jointer knives (about $30.), by holding the blade at a fixed angle while you sharpen against adhesive backed sandpapers on sheet glass. It takes some practices, ads it is easy to exert more force on the ends of the knive and create a slight camber or curve to the edge of the blade. I have not used any of the horizontal wheel grinders. For planer blades I sharpen infrequnetly and just send them out to a local serviec here in Atlanta.
Jay
Where in Virginia? Theres gotta be 50 places in DC area alone....Three wihin 10 minutes of my house. Jimmy
I'm south of Charlottesville (Covesville which is a wide spot in the road to be precise). I'm going to try sharpening the knives myself using the jointer fence to set the angle -- I'll let you guys know how it goes. First though -- I need to put together a magnetic blade setting jig.Dave M.
I'd love to see your design for a better jointer knife sharpening jig. I make lots of jigs myself for repetitive tasks, but sometimes I feel my limited shop time is better spent building the projects and furniture I want to make, and I've broken down and bought tools or devices I know I could have made myself.
Jay
im new to woodworking from a man with 47 yrs building to me " kid if your going to cut wood forrest is the only game in town new or redo "
forrest is the only game in town ?? Not knocking what you like.. We all have our own thoughts.. I have used the Forrest and what I usually use.. The FREUD blades from Italy.. OK so a Chicago child raised in a Italian neighborhood! I for one think the FREUD is as good at a better price... Just me though. I'd say each is a QUALITY blade!
Are you speaking of the blades, themselves or the sharpening service? Or both?
This site will show how to made a jig.
http://www.superwoodworks.com/Projects/JKnifeJig.htm
good luck.
Boogalee,<!----><!----><!---->
That’s a really clever jig. <!----><!---->
I am curious however if it’s necessary to flatten the back of the jointer / planner knives in a similar fashion to flattening a plane blade? How about creating a micro bevel? <!----><!---->
Neil<!----><!---->
I would think a flat back would be part of the sharping process.
I'm not sure about the cicro bevel.
good luck
That is WAY cool. I'm going to make one for my shop.
Mike D
Flactem
The best and cheapest sharpening service for planer blades is going to be a printers service. Printers use what look like planer blades in spreading ink and they must be extremely accurite. Plus printers use blades so often they have some in rotation all of the time.. they really need to remove as little blade as possible.
Surprisingly a lot of sawblade sharpening services use printers service type places and simply mark up the service..
Look in the yellow pages or call any printer in town..
Wow. Amazing piece of information -- goes to show the value of these discussion boards. I am going to try and sharpen the blades myself -- but if I run into problems I'll try my local printer.Thanks,
Dave
Flactem
I have no doubt that you will be able to achieve something yourself. I bought a Tormex to do so thinking in the time it took me to haul them in I could have saved the cost.
What I found is that The Vaunted Tormex blades didn't last half as long as the professionally sharpened blades did.. plus I removed twice as much material each time I sharpened them.. That wasn't critical when they were new but became real noticable as I wore out the blades. Eventually leading to balance problems..
Granted I went thru 40,000+ bd.ft. of hardwood in a few years so I really used my planer's/jointer a lot and wore out a lot of sets of blades..
