Yo!
Large project involving cabinet doors with 1/4″ panel with walnut veneer vacuum pressed to each side installed into a shaker style frame.
2 questions-I’m looking for shaker style rail and stile bits-adjustable if possible. I’ve looked through all my catalogs to no avail…
and
what would be the best substrate for the walnut veneer-it is beautiful old stock and thicker than normal. I’m planning on using 1/4″ particle board but would 1/4″mdf be a better choice?
Love the forum!
thanks,
silver
Silver,
MDF would be a much better choice than particle board.
How thick is the walnut veneer?
Rich
Don't ever learn anything new. Rather than give you satisfaction that you know more than you did, it will only confirm you know less than you thought by opening horizons to things of which you had never dreamt and which you now must explore.
Hello Rich 14
modern veneer I think is 1/64"
this 50 year old walnut burl veneer is 1/32+
We already made the board room table and now we are building a buffet centre and multi media centre to match.
The board room table is the walnut burl veneer with solid oak edge...and the idea is to have the doors on the centres match the table...
I'm confirming an order right now and will add mdf. Why is it better??
cheers,
hiho silver
Silver,
I would never use particle board for furniture. MDF is much more uniform and dense (and probably stable). The glues are higher quality and the surface is perfectly flat, smooth and uniform. You could glue 1/64 veneer directly to it without problems of its surface texture telegraphing through.
There is, of course, furniture-grade MDF and lower quality MDF. Ya gets what cha pay for.
Particle board is junk (C'mon Rich. Don't hold back. How do you really feel about it?)
Rich
Rich 14
That was what I was thinking about mdf...however,a fellow woodie told me that his research indicated that over the long term, particle board would stay straighter...I think particle board is still the substrate of choice for plastic laminate.
anywho, that's for setting me straight!
I also have a buffet table top 24" wide x 112" long -walnut veneer with an oak edge...
unsupported on the front edge for 65"...a double layer of 3/4" mdf with staggered joints and the oak edge will keep this straight ?
thanks!
silver
Silver,That's a lot of unsupported span. What are the actual dimensions of the front oak strip?Two thicknesses of MDF will be stiff, but unsupported over time they may sag a little. A torsion box construction could help.Rich
Rich14
The oak strip is 1-3/4 x 1-3/4 w/ a round over
The conference table is torsion box construction but I was trying for easier on the buffet table
that is wall mounted on the back side.
silver
particle board Ohhhhhhhhh geeeeeeeeeee
You could also consider 1/4 baltic birch as the substrate. It will take the glue better, it is lighter and causes less dust when cut.
Doug
Silver
I have been looking for cutters for a project that I am on and saw "Shaker" rail and stile router bits that may be adjustable at eagle-america.com Their PN 185-0500.
Good luck
Dave
Thanks BigDave1
Freud also has a tongue and groove cutter that they call a shaker door set in their catalog that one of my students found for his project. I'm checking them both out.
cheers,
silver
