I have read somewhere that there is a water based polyurethane that will go over latex paint to seal it with out adding color to the latex color. Does anyone have experience with which one it is ? I need to seal a book case form sticking to the books.
I've done a couple of painted projects using latex paint followed by polyurethane, and both came out well.
The trick is to let the paint dry for a couple of days before applying the poly. Latex quickly forms a "skin" that feels dry but is still moist beneath the surface. It needs to cure for a while before it will resist sticking to whatever is on it.
Another option is to use a latex formulated for "high use" locations. Three years ago, I built an entertainment center for a customer who asked me to use a Kelly Moore paint formulated for "heavy use" (furniture, doors, etc.) I was a bit skeptical, but the customer tells me that it's held up well.
You can use a waterborne acrylic finish like Minwax Polycrylic. This finish is water clear and will not cause a change in color of the underlying finish. However, if you used a wall type latex paint, you may end up with the books leaving indentations in the surface even with the clear coating. Latex is not a good substrate for a surface that will get any real abuse or long term weight.
