Here is my story…
I’m working a cabinet that has two doors below a couple of drawers. Each door is about 12″ wide and 13″ tall. I was able to find a single board of mahogany that is wide enough so I could make each door out of a solid piece. Great. So I set about the task of flattening that wide board, which went well. I set it aside to settle ’cause I figured it move a bit and it did so I flattened it again and let is rest some more, fattened once again, let it settle…
Well I’m running out of board so I decided to make veneer out of it which went pretty well. Now I need to select a substrate to put it on. I’m not to thrilled with using MDF for the core. I know it will stay flat but I just can’t see using it on this piece. and just like MDF. I thought about lumber core substrate but I can’t seem to find any, and most of the baltic birch ply I’ve looked at so far isn’t very flat to begin with. So I thought about making my own lumber core substrate from poplar.
He is my plan. Cut strips about 1-1/2 wide and 1/2 thick. Joint and glue up a panel being careful to alternating the growth rings to keep it flat. Put the veneer on both sides, and I have a door that should stay flat.
I figure if I keep the veneer at 1/8″ thick or so I should not get a whole lot of washboard effect from the alternating growth rings and the panel shouldn’t cup.
Have I thought of everything or does someone have a better idea.
Thanks for the thoughts,
Greg
Greg,
You plan sounds good, just make sure to keep the panel very flat as the glue is drying. You may want to glue up the substrate and allow it to adjust to the atmosphere of your shop before gluing on the thick veneers.
Stephen Shepherd
http://www.ilovewood.com
