I am making furniture that requires large numbers of slats in the seat and chair backs which have a 1/2″ roundover on all edges. I am looking for the equivalent of a drum sanding attachment for a drill press that wil sand the rounded eges with out flattening them. This would look something like an hourglass in profile. Any suggestions? I am spending way too much time trying to hand sand with a piece of sandpaper in the palm of my hand to conform to the convex curve of the edges.
Another method is to hold the ends of the sandpaper as you would a polishing cloth when shining shoes, conforming the curve to the wood and pull it back and forth. Most of the time, I just use a finish sander with light pressure and keep it moving so as not to create flat spots.
Another option is the Festool LS 130 EQ Duplex linear sander (around $340) or finding a (now discontinued) Porter Cable 9444 Profile Sander (around $120). If you Google "profile sander" you'll find listings for both, and some dealers still have the 9444 in stock.
profile sander
Like this:
http://www.festoolusa.com/products/specialty-sanders/ls-130-eq-linear-sander-gallery-567777.html
Pneumatic is the word
Have you looked at a pneumatic sanding drum? By decreasing the pressure inside, the sanding drum will better conform to the profile and not leave flat spots. You might also consider sanding sponges or making a sanding block with the negative profile, using (expanding) foam or another material.
Scrape it
Maybe cut a half moon shape out of a steel scraper using a hack saw to cut the bulk out and then a fine round (chain saw) file to refine the shape. Hone to sharpen just a square sharp edge on and then scrape the slats/work as needed. Try this article here on FWW or search Scratch Stock or Scraping.
https://www.finewoodworking.com/Materials/MaterialsPDF.aspx?id=2851
